Question about GE JKP27 Electric Double Oven
I have a GE electric double wall oven. The lower oven works well. However, the upper oven will not bake, broil, or self clean. It does still show light indicators for each feature. The broiler and baking elements have been replaced with new ones. A repairman came out (approx. 2 yrs. ago) and told us that it was a problem with the control panel and the panel could not be replaced. We need confirmation there is no replacement/repair option! GE Model #JKP27G, Serial #607205G.
  • PeepAnne Nov 18, 2009
    Do you have any suggestions on locating a used/old model of this type so we can replace the panel? Also, thanks for your quick response...PeepAnne
    Thanks! Will do!...PeepAnne
  • 986 Answers
I just did some research myself. Yes the repairman was correct. Those parts are listed as NLA (no longer available). All you can realy do it locate a used on and try to replace that panel for yours. It a old oven. Sorry I couldnt be of more help. Best of Luck
Posted on Nov 18, 2009
  • Roger Campbell
    Roger Campbell Nov 18, 2009
    Honestly.... I would look on Ebay, craigslist, Appliance recycle and scrap places. You may even get a break in the paper. I would even post up a wanted ad on Ebay and Craiglist. Its going to be a hard search. Maybe even a ad in the local papers, someone doing a remodel may just give one away. Best of luck to you.
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
May 12, 2014 | GE JTP45 Electric Double Oven
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
GE electric double oven
Colin, the TCO is located on the back of the oven. It will open L2 to the heating element in the event it is open. If this TC0 opens it will not show any error codes. This is for the 27 inch wall oven models only. Catriver...post back.
Nov 09, 2006 | GE JTP48 Electric Double Oven
Ovens Logo
140 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
