Question about Sony CDP-C305 5-Disc CD Changer
I took the disk changer apart to re-cage the mechanism holding the CD in place when it is playing. It had basically jammed the drawer from opening or closing properly. I had to remove the four tension springs holding the carrier and did not realize that these springs were all different tensions and color coded. I did not put them back correctly and need to know which spring goes where according to tension. Right now the player "skips" while playing but it was working perfecty before all this happened. What are the proper placements of these four springs?
Cannot eject the cd from ıts cage
Posted on Nov 30, 2009
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Sony CD player CE-415 Drawer will not open.
This will require a professional, the more CD'S this unit can take the more complicated the loading bay will be. The most common problem is gear timing where the system is knocked out of sync and often locks down the device to prevent further damage. Sometimes the gears will strip jamming whole mechanism.
Mar 15, 2012 | Sony CDPM400CS 400-Disc MegaStorage(r) CD...
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Mech Comm Error
sounds like they may have forgotten to take out transit plugs from radio which holds cd mechanism in place when shipping unless you got a new radio thats a dud? but that may also mean dealer didnt check operation of new unit after replacement if replaced which is what usually needs to be done when this error message comes up
Aug 06, 2009 | 2005 Jeep Grand Cherokee
Cd changer not eject disk what in side and wont play !!
you have a mechanical problem with your cd changer you need to take it apart to get your cd back
Jul 21, 2009 | Car Audio & Video
CD Changer not reading CDs
2000 bmw 528i,my cd changer also reads no cds,this seem to be a common problem with all bmw cd changer.Anyway i removed the cd changer from my car,took the outside black cover apart only to see that a white big wheel came of its place,(its the wheel that holds the cd in place from the top (bottom wheel is black attached directly to the motor,as the cd is sandwitched between the black,and white wheels) .if that wheel is out of place the cd will not turn inside the changer for the eye to read it,so your radio screen will read NO CD OR NO DISC.Very easy fix,just place the wheel in its place,and everything worked fine,it took me 20 minutes to fix.
p.s :
1- you do need to make sure you have an original cd in for testing it.
2- you do not need to recode your cd changer at the dealer if you have an old bmw,dealer will need to recode cd changers for 2006 and up.
Good luck.
Jun 15, 2009 | 2001 BMW 3 Series
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
Jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Jan 06, 2008 | Audio Players & Recorders
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Sony CDP-C305 5-Disc CD Changer Logo
249 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
