Question about Cuisinart TOB-30 Classic 1500 Watts Toaster Oven with Convection Cooking
Cuisinart toaster /oven TOB 30BC I need the middle plastic function dial Where would I buy it? I am in Toronto ,On
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
I have the same problem. It is due to a bad relay switch in the toaster. I have found that for now, my toaster will work if I leave it on the "TOAST" function rather than "OFF" overnight. I think it lets some current or voltage hit the relay and encourages it to work.
I will try to replace the relay and post a "how to" on that when it is done.
May all of your toasting be succesful.
Posted on Jan 21, 2008
SOURCE: Cuisinart Model TOB30BC Control Function
My toaster oven would not turn on. At first inspection it was not obvious what the problem was. But after sanding the contacts, and cleaning the contacts and cam with rubbing alcohol/cue-tips and a paper towel, as Caseytronic suggests above (let every thing dry completely!) It works like new now. Just be sure to turn off the power first as there is a lot of bare metal in the electrical circuit in here.
Posted on Mar 19, 2008
  • 30 Answers
SOURCE: CUISINART TOB 175 CONVECTION OVEN MANUAL
Cuisinart has the manual on their website:
http://www.cuisinart.com/manuals/index.php?cat_id=15
Scroll down to the link for the TOB-175.
Posted on Dec 30, 2008
SOURCE: Cuisinart TOB-30 toaster oven
I have the identical problem. Where can I find a replacement foot?
Posted on Mar 14, 2010
SOURCE: Door spring broke on Cruisinart CTO 350 series Toaster Oven
I had same problem with my cuisinar 350 series broken door spring. After disassembly found a broken extension spring measuring about 3/16 dia.,by 6.5 inches long.Spring was broken about a third down. I lifted ,or bended a loop and a halve up from each broken section and joined the two sections together. lifting each loop of the spring is tricky at first, requires a small screwdriver to be inserted between loop to be lifted and then gently bent the loop with needlenose pliers.
Not knowing how to disassemble the unit I had a hard time assembling the unit back.
I would start by taking off the screws holding the front black backlite first, then the main cover.
The main stainless steel cover does not have to be removed completely, by just gently unbending
the cover I was able to access the spring for removal.
Lots of luck
Posted on Nov 10, 2010
I have a cuisinart toaster oven. Model TOB 30BWC. The selector/timer dial doesn't work so the oven is always on when it is plugged in. I would like to get a new dial
Looks like replacement knobs are not available from Cuisinart.
However, any 1/4" shaft knob with setscrew should work.
If you have a Radio Shack still in business near you, they are blowing them out for under a buck a knob:
RadioShack Hexagonal Control Knob
Other styles and sizes are also available.
If you do not feel like looking around, here are a pair of universal knobs that should work, although they do not look the same:
Part TOP1345 for Cuisinart TOB 30BW Appliance Factory Parts
Mar 26, 2017 | Cuisinart Toaster Ovens
How can I get a copy of instructions for Cuisnart convection oven TOB 165?
Cuisinart has the manual for the TOB-165 on the Product page; it's a discontinued model. See https://www.cuisinart.com/discontinued/toaster_ovens/tob-165.html . The direct link to the instruction book is https://www.cuisinart.com/share/pdf/manuals/tob-165.pdf . (Note: you will need Adobe Reader or a similar program to read or print the manual.)
I hope this helps.
Aug 09, 2015 | Toaster Ovens
Where can I purchase the three knobs for the TOB-30? I cleaned all the ink off of them.
You can get them from Cuisinart at 1-800-726-0190 - the availability varies -sometimes they have them in stock, sometimes they don't
Jul 20, 2009 | Cuisinart TOB-30 Classic 1500 Watts...
Mar 14, 2009 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-175
It is roughly 17 inches across from left handle to right handle, but slightly less. About 15.25 inches from front to back.
-Tha Mp3 Doctor
Dec 30, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Nov 19, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Warning tone?
Have you tried turning the function button to off? This has worked for mine.
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster oven just stopped working...
With mine, the toaster function stopped working. The light lit, but the relay did not click. This happened about a year ago, but then it started working again. Now that my waranty expired, it seems permanent.
The relay requires 12V, but I only measure 5V (no audible click). When I pulled the relay, the drive went up to 12V, so the coil is loading down the source. Not sure whether the problem is the coil or the source. It would be nice to find a schematic. When I put the relay across a car battery, I heard the click indicating that the relay is working.
I cleaned the contacts, and get the same result.
Jul 22, 2007 | Cuisinart TOB-30 Toaster Oven with...
Cuisinart TOB-30 Classic 1500 Watts Toaster Oven with Convection Cooking Logo
121 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
ray gallant
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
