Question about IBM 2611 1400I (10L1175) Motherboard
Ibm 2611 laptop display problem what i do tell me the possible reasons
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 18, 2009
Ibm think pad 2611 1452 cmos battery how to replace
There are multiple panels on the underside of your laptop. You can start by removing those and seeing if you can locate the battery there. If it is not under those panels than try removing the keyboard. If you still can not locate the battery from these then you will need to completely disassemble you laptop chassis to locate the battery.
I wouldn't suggest disassembling the entire chassis as reassembly can be difficult.
Nov 21, 2011 | IBM ThinkPad Computers & Internet
Power supply brick specs for Thinkpad 2611-412 volts / amps
A 19-volt 65-watt adapter is needed. Here's a suitable replacement at Amazon.com, and there are many more sources.
Sep 14, 2011 | IBM ThinkPad i Series 1412i Notebook
I have a ibm thinkpad that was giving to me ,but when i power it up it displays no operating system found?
The reason why no operating system was found is possibly the hard disk has been wiped clean. You need to install Windows and the ThinkPad device drivers and any programs you need to get a fully operational laptop.
If you are new to setting up a computer, you need to get assistance from a computer savy friend.
Aug 14, 2010 | IBM Computers & Internet
I want a ibm thinkpad i series 1412 vga driver
You need to check the type number on the service pad at the bottom of the laptop, if you cannot find the type, download both vidoe drivers, the wrong one will just not work.
· i Series 1400, 1500
(Machine Type - 2611)
i Series 1400, 1500
(Machine Type - 2621 and 2651)
Apr 15, 2009 | IBM ThinkPad i Series 1412i Notebook
Ibm t41 thinkpad display problem
actually its the problem of the cable that gives display to your screen , open your laptop and replace this cable
rate this solution
Oct 15, 2008 | IBM ThinkPad T41 2373 Notebook
Volume buttons
Click to "Access IBM" button , Thinkpad Configration window or webpage, Thinkpad Configuration program will appear.
GoTo : Thinkpad Config->Display->On Screen Display
You can see there or it may there on some other option, on this configuration program. It may help you.
Cheers - Parveen
Feb 06, 2008 | IBM ThinkPad T41 Notebook
IBM 2611 1400I (10L1175) Motherboard Logo
338 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
