Question about Gateway MX6448 Notebook
Replacing the whole monitor screen and bezel
I have a perfectly running gateway MX6448 notebook with a broken monitor. I have a replacement monitor and was wondering if anyone had any suggestions as to how to remove the old one? I have the screen and bezel both, so I would assume it is removed at the hinges and then plugged into the MOBO. Any advice would be appreciated.
  • 788 Answers
Usually there is a plastic cover that snaps off right about the keyboard that covers the hinges. It is sometimes screwed from the bottom of the notebook thought. Once that is removed you should have a clearer view of what needs to be done. Sometimes there is a few screws from the bottom or back of the system that hold the hinges and sometimes the screws are on top of the hinges. You should also see all the cables that go from the screen to the system, unplug those. Hopefully that is all you need to do, but sometimes you have to remove the keyboard and palmrest to get the screen off. Good Luck!
Posted on Jan 10, 2008
Replacing laptop hinges
There are 2 set of cable that run from the display to the monitor, be very careful with it. In most cases, to remove these cables you need to disassemble the whole laptop. Now, since you are on Y changing the hinges, I think you can do it, just don't pull on the monitor too hard, and it needs to be place on a flat surface very close to the laptop. It's not that hard, you just need to be careful, that's all.
Jun 20, 2013 | Gateway 7330GZ Notebook
I need to replace the inverter in my gateway 7210gx. How do I remove the bezel around the screen?
Remove the screws that are mounted underneath the rubber bumpers. Then carefully pry open the bezel.
Jan 02, 2011 | Gateway 7210GX Notebook
MX6448 power
If these are the only symptoms, then chances are the problem is either (1) a bad battery that is no longer retaining a charge or (2) the charger is not charging either because it is bad or the plug on the laptop is broken (which is repairable but maybe costly due to labor cost (approx 1-1.5 hr task)). I presuming it is not under warranty.
If there are other symptoms, it would require testing to determine; not a task for a DIYer except if it's a bad battery or bad charger.
Feb 25, 2009 | Gateway MX6448 Notebook
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
Gateway MX6448 Broken hinge mount
They are probably available at: but this is not a task for a DIYer.
Unless you have the tools/experience to dis-assemble / re-assemble, I strongly recommend you have repaired by a competent shop or contact me ( pls reference this response.
Oct 25, 2008 | Gateway MX6448 Notebook
Gateway MX6448, screen is stretched problem is not screen resolution
On the desktop,
right click and go to Properties
then goto Settings
See the horizontal bar,
move it left or right to change the display settings
Apply and Ok it
the screen will refresh and you can ok it or go back to previous settings and try something else
Oct 17, 2008 | Gateway MX6448 Notebook
No display on screen and solid amber light on pcs' power button
it seems to be an issue with the power supply as you already tried replacing the motherboard
power supply will be less expensive do try to get it replaced first
do check that monitor iss fine
unplug the blue VGA cable which connects your monitor to the tower
if a 4 colored box moves all over the screen the monitor is fine
and if it doesn't
get the monitor either repaired or get it replaced.
Jun 06, 2008 | Intel Motherboard
Gateway mx6448
The biggest removable door held on by about 6 screws on the bottom of your laptop is what you need to remove. Once inside you will see your heatsink! Very easy to access, I wish you luck.
Mar 11, 2008 | Gateway MX6448 Notebook
Gateway MX6448 Notebook Logo
173 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
