Question about Hardware & Accessories
Bathroom doorknob stuck in locked position.
My bathroom doorknob is stuck in the locked position. How do I fix this?
    Scholar:
  • 106 Answers
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Posted on Apr 09, 2010
Handyman took doorknob off door to paint it. Now I can put my key in it, but it won't tur. How do I fix this?
the knob was installed when the lock was in the wrong position
do the installation again
if that is beyond your capabilities get in another handy man with real knowledge of things around the house
Apr 20, 2016 | Cars & Trucks
How do I remove my Doorknob
break it off or replace the whole door
Sep 04, 2014 | Locks & Locksmithing
Broken interior door knob door will not open.
well if you havent been able to get the cat out by now its dead but looking at the pics only way you can get in is by jigsawing the latch out
May 23, 2012 | Hardware & Accessories
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
My soon lock the bathroom door from the inside and now i cant get into the bathroom. how do i get the door knob off so that i can get inside the bathroom?
The short answer is that you can't get the doorknob off from the outside.
Lock sets and door knobs are purposely made that way to thwart any potential thief with a screwdriver from simply removing the door knob to gain access into our homes and rooms.
What you MAY TRY is to carefully pry loose the door trim in the area of the door knob away from the door jamb. You may have to carefully remove a trim nail in the process.
Then experiment with a flat, thin, solid tool like one of those rounded spatulas used for frosting cakes slipped in between the trim piece and the jamb. Your goal is to try to get the spring latch to retract away from the door's strike plate like James Bond with a credit card. Look at one of your other open doors to visualize how the mechanism works.
This is going to require some patience, but it may save you from having to destroy the door or frame to get into the room.
Jul 27, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
The key still goes easily into the doorknob
can be easy as wd-40 squirt of oil. try that first... then on to more drastic measures
Dec 13, 2009 | Schlage BE365-CAM BE365CAM620 Antique...
Doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Mar 12, 2009 | Top Knobs M826 Door Pull
Hardware & Accessories Logo
1,379 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
