Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Go to turn on blinks green like normal then turns on real quick moment than shuts off and blinks red 4 times pause four times
  • Sony Master
  • 586 Answers
According to the symptom on A Board +13volts not being supplied, and this is due to IC561 Details(Part No. and Description) of IC is given below:
8-759-980-58 IC TDA8172
which is not working please replace it and your tv work fine again.
Thanks for using fixya.
Posted on Nov 18, 2009
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
TV not staying on
I called a tech and it was a convergence issue. It cost $375 to fix.
Jul 05, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
