Question about Air Tools & Compressors
My speedaire compressor hasn't been turning on automatically to keep the tank filled with air, The reset breaker pops and so I have to rotate the pullys a few times and then push the reset button which then starts the motor. Half the time it starts automatically but most times I have to manually reset and start it. Why?
    Problem Solver:
  • 7 Answers
Sounds like the release valve is not working. When the compressor shuts off, you should hear a slight hiss, draining residual air in the cylinder. If the motor starts up and can't rotate, it will blow the breaker. When you rotate the pulleys, you take the load off giving the motor a fighting chance.
Cabinetman54
Posted on Nov 19, 2009
What will cause my Kohler Command Pro 12.5 Engine on an air compressor to shut down after the tank fills instead of going to an idle. Carb is new.
Does this have the solenoid on the bottom of the carb? That is a automatic shut off device installed in the pot of the carb to shut off the gas if the carb is overflowing with gas. If the carb is new, is the solenoid? Also, is there a bleeder line for condernsation to the tank on the bottom of the air tank? If so, sometimes that is a problem. Too much water inside the air tank. I don't know if it would cause this problem though.
Sep 29, 2014 | Dayton Audio Dayton Speedaire Air...
I just bought a new craftsman prof 27 gal air compressor. it is oil lubricated. i let it run for 30 mins like the manual said to break it in and then filled the tank. i was putting air in my tires and it...
It sounds like the small valve that releases the pressure out of the main pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch. If the valve appears to be working then it means that the Non-return valve on the input to the tank is not sealing properly and letting air back into the main pipe causing the compressor to start under load. Check both valves for correct operation and if not working properly, talk to the people you bought it from to have it repaired under warranty seeing that unit is brand new .
Feb 16, 2011 | Craftsman Air Tools & Compressors
My craftsman 1.5hp 20gallon comperssor starts fine with an empty tank, and will fill the tank, but will throw the built in breaker when it needs more pressure.
Your tank valve is stuck open. The valve is on tank where the tube from the air pump goes into the tank. It allows air into the tank but not back out the same way. When the pump stops you hear a short burst of air leaking out that releases the pressure on the piston in the cylinder. If the tank valve sticks open, the pressure in the cylinders is more than the motor can overcome to restart and the breaker pops open so the motor won't burn itself up. The valves are relatively easy to get and easier to replace.
Oct 22, 2010 | Campbell Hausfeld 20 - Gallon Air...
My compressor will start and run well but when it turns off it will turn but not run stalls and kicks the breaker
Sep 17, 2010 | Porter Cable Cable 20 Gal 150PSI Oil Lube...
Cdewalt d55133 compressor. compresor fill air tank but when engine try to start again humms and the breaker come on and wont start
It sounds like the valve that releases the pressure out of the pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. This valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it. You know the valve is working by the sound of a short spurt if air being released when the motor cuts off. If the valve is not releasing this air the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start.
Aug 25, 2010 | Garden
My Makita MAC2400 air compressor keeps blowing the circuit breaker. The circuit breaker to the compressor not the one for the house. It will only run for about 15-20 seconds before the breaker pops. I have...
Your compressor should fill within 5 min or so. Here are a few things to check. As compressor is running check all air connections/fittings with soapy water (including regulator, drain fittings and quick connects). Repair as needed. If no leaks, unplug compressor and listen for air leaking from check valve at tank (remove 1/4 airline at checkvalve, brass valve at tank). Replace checkvalve as needed. If no leak at checkvalve, problem most likely valve plate in head of pump. The valve plate has two reed valves that sometimes break. Bad reed valves will cause compressor head to become very hot and discharge air will be hot. Replace as needed. Parts are available at www.toolpartsdirect.com. Good luck.
Aug 05, 2010 | Makita MAC2400 Electric Powered Air...
My compressor fills up and leaks. I have replace
If it is leaking out after the pump shuts down on the switch, then it maens that the tank check valve is not holding, it is located where the pump discharge line enters the tank, drain all air from the tank and then remove the valve and replace it.
Mar 15, 2010 | Craftsman Air Tools & Compressors
I have a 2hp compressor motor that keeps tripping the breaker after about 5 minutes of use. i have changed the caps but it keeps popping the starter cap. is the motor just bad?
Our 2 HP Speedaire horizontal tank compressor is rated 115 / 230 volts at 24 / 12 amps, respectively. This means at 115 volts, a 30 amp circuit breaker is the bare minimum. That also means that the wiring should be #10 copper wires for short runs, but the next size up; #8 copper wires would be better connected to a 40 amp circuit breaker. Running at 230 drops the amperage requirement by half, to 12. A #14 copper wire is minimum for short runs with a double pole 15 amp circuit breaker, but #12 copper wires connected to a double pole 20 amp circuit breaker would be better choice.
If the compressor is cord connected (or even directly wired) with the minimum sized wires, it will likely a voltage drop problem unless very close to the panel. This problem is more pronounced as the distance between the circuit breaker and motor increases, or when smaller wires are in the circuit. All the voltage at the circuit breaker does not reach the motor, as it is lost as heat; so the compressor only sees 90 to 105 volts instead of the 115 volts it expects.
If the cords, connections, etc are getting hot, it is a tell tale sign of under-sized wires and /or poor connections. Once you solve these problems, the compressor should run "as advertised " because motors usually don't "go bad" but fail all at once. Unless you have a bearing problem - or there is a problem with the load itself (compressor).
I hope this helped.
Nov 12, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Jun 16, 2009 | Ingersoll Rand 2545/7100 Electric Air...
Compressor tries to keep running pops the breaker
Inside the control unit is a spirally spring like diapragm, it holds a ball bearing that should shut off the compresor at max pressure. The ball bearing has probably fallen inside the tank. Now it won't shut off so it tries to keep runniong. The back pressure cause an overload on the compressor motor and so blows the breaker. You need a bigger ball bearing or a replacement diaphragm. However you cannot get parts as there is a safety recall see this site: http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Apr 02, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
247 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
