Question about Philips DVD724 DVD Player
I created a vob dvd using ImgBurn on a Memorex DVD+RW disc. It plays fine using Power DVD on all of my computers, but when I try to play it on my Philips DVD724 it skips, crackles, and the audio and video are out of sync. Any ideas on anything I may be doing wrong or what I can do to correct this?
  • Philips Master
  • 2,385 Answers
Use Nero Burning ROM application for best result.
Posted on Nov 18, 2009
Why wont my dvd+rw play in my dvd on tv?
They are differnt formats. DVD's are VOB files in a TS Video folder. You got a computer file of some kind. Like AVE or MP4, and so on.
Dec 30, 2012 | Memorex DVD+RW Discs - 4.7GB, 4x, with...
Tip
Play Blu-ray movie with HDTV DVD Combo ? Burning Blu-ray to DVD
HDTV DVD Combo features a built-in slot-loading DVD player, which provides an optimum way to save space. With the slim profile, it’s really an amazing experience to watch favorites TV shows and DVD movies on this device in your bedroom. But if your TV only has a standard DVD player but not the Blu-ray disc player, what is your solution to play Blu-ray movies on it? I'd like to know your ideas. I believe my way is somewhat helpful, just convert BD to a DVD format, and then burn it to a blank DVD for playback on the TV/DVD Combo, so share it here, and also be glad to hearing from you guys.
The software I used is as below:
- (http://www.pavtube.com/blu-ray-ripper/ ) Pavtube Blu-Ray Ripper
- (http://www.videohelp.com/tools/ReJig) ReJig (freeware)
- (http://fileforum.betanews.com/detail/ImgBurn/1128426215/) ImgBurn(freeware)
HOW-TO:
Part 1:
Firstly, use Pavtube Blu-Ray Ripper to remove copy protections of Blu-ray movies, and meanwhile convert it to the DVD vob format.
1. Run Pavtube Blu-Ray Ripper and click "DVD Rom", "DVD Folder" or "IFO/ISO" to load Blu-ray movies. Generally speaking, the file with the longest duration time would be the main movie, if you just need back up the main movie, tick off this one only.
Each file will be checked by default after imported, right click on any one of the files, and then there will be a popup window to let you uncheck all, just do it, and afterwards to tick off the checkbox before the file you need converted.
2. Click on the drop-down menus after "Subtitle" and "Audio" respectively to select your required languages and sound effect.
3. Select VOB as output format and specify destination folder
Click on the pull down list of "Format" to select VOB as output format and click on the folder icon at the opposite side of "Output" to specify destination folder.
4. Customize output settings
The popup window will allow you to adjust audio and video parameters including codec, bit rate, aspect ratio, frame rate, sample rate, and audio channels to optimize the output file quality.
5. Click on "Convert" button to start BD ripping
Once finished, you can find out the output files via clicking on "Open" button with ease.
Part 2:
Then use ReJig to do DVD authoring.
It's pretty simple with ReJig. Press "File Mode"; add your vob files and Demux.
When it's finished, close that box and then select DVD Author. Add the video and audio files you've just created, and choose output destination folder, and click Create.
After DVD authoring is completed, you can open the destination folder to see that the output files are AUDIO-TS and VIDEO-TS folders, which are the correct structure for DVD burning.
Part 3:
Use ImgBurn to burn DVD
We have got VIDEO-TS folder in part two, so the DVD burning process with ImgBurn is pretty simple. Here give you two links to check the detailed steps:
(http://forum.imgburn.com/index.php?showtopic=4632 ) How to write DVD Video files directly to single layer media using ImgBurn (DVD±R/RW)
(http://forum.imgburn.com/index.php?showtopic=4643) How to write a DVD Video double layer disc using ImgBurn (Verbatim DVD+R DL) – just check the contents that start from adding VIDEO-TS folder of this guide.
The end! Hope this helps.
on Mar 10, 2010 | Televison & Video
I Have a Memorex MVD 2047 DVD Player thats supposed to read DVD RW disks but it doesnt read them help?
Like you said the unit is capable of playing DVD RW and DVD-RW. However, some discs may not be compatible due to format of the files on the discs, software used and laser pickup. Some technologies used to record on discs can prevent optimal playback of the files by changing them which affects the ability of the player to read the file.<br /><br />If you are burning the discs, I would suggest you different software, make sure the video/audio files are being converted to a DVD format that can be played on stand alone players. <!-- from fixya rte -->
Aug 06, 2010 | Memorex MVD2047 DVD Player
Pinnacle S 10.7 DVD plays for for 15 min plus and then image free
Unfortunately I do not know what a prosumer is (do you mean producer?) but what I would do is produce an image file rather than write direct to disc and then use nero or imgburn to burn the disc.(I prefer Imgburn and not just because it is a free open source prog).
Give it a go and get back if the problem remains.
Jul 08, 2010 | Pinnacle Dazzle DVD Recorder
Which recordable dvds play on this dvd player
this brand and model should be able to play the discs you mentioned witih no problems, unless it is defective, or a error is being made when you are recording the discs. If you are recording and they ar enot playing, most likely you are not "finalizing" the discs durring the burn processs. All discs MUST BE finalized to be played on any dvd player.
Feb 08, 2010 | Teac DV-3500 DVD Player
100% burns xbox360 game but says play dvd when i put in xbox
Chances are what you are copying is COPYRIGHTED and the electronic protection will prevent you making a USABLE copy that the Xbox will run.
Nov 05, 2009 | Sony Computers & Internet
Discs will not play back on dvd
What DVD's are you using +R/RW -R/RW some formats may not work especially on non-branded media some DVD players wont even play CD-R but will play some CD-RW of the correct brand.
I suggest that you try your finalized DVD in your PC then create an image using ImageBurn then burn the image onto a branded media and try again. Most firmware on DVD burners are very forgiving and will support a wider range of manufacturers and formats.
Hope this helps, you might want to look on your DVD players website for updated firmware you will need a blank CD and create a update disc using your computer.
Oct 18, 2009 | Sony DCR-DVD91E DVD Camcorder
DVD won't play through DVD Player
2 questions. Did you finalize it when you burnt it? Did you record it as video dvd or a data dvd?
May 31, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Memorex DVD+R DL 8.5 GO 8X compatibility
If all you are looking to do is write a DVD (ie, burn ordinary OS-managed files onto DVD, without transcoding, etc.), or write transcoded DVD-structured files, or an .iso image file, then don't even try to use Nero. Use ImgBurn, it is 500% better for those kinds of tasks, and it's freeware. I use it to burn DVDs but use Nero to transcode files and create the VIDEO_TS folder files. I then use ImgBurn to convert them to an .iso file, then burn it to DVD, also using ImgBurn. URL: http://www.imgburn.com/
Mar 30, 2008 | Ahead Software Ahead Nero 6.3 Suite 1...
Philips DVD724 DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
