First reset the cmos bettery and check the cpu fan is working or not. And cpu fan also disconnect & insert
  • Dominic de Groot May 11, 2010
    i dont know what u want me to tell you
  • SANTOSH KUMAR May 11, 2010
    pls provide the issue detail what aru your issue
    Problem Solver:
  • 6 Answers
Take the battery out wait about 5-10 minutes and put it back in. check for any damage and restart!
if you want to restart your bios then look for the DIP switch
Posted on Nov 18, 2009
  • 23 Answers
It is not in cmos battery .........You need to put of the battery and the start the computer it will then reset.Then put back and the fan will work
Ho to remove toshiba sattelite A10-s167 bios password keeps giving a password prompt but i forgot it now
just open cpu cover & remove cmos bettery from mother board then start the system then again put it just restart
Apr 16, 2014 | Toshiba Satellite A15-S127 Notebook
Fan spins but it will not start up
Try reset the memory, CPU and check the CMOS battery voltage. ( 3 Volts )
Disconnect the main harness from the power supply before any of the above is completed.
Sometime, the CMOS battery on the Motherboard goes south and sometime just re-seating the memory and CPU will be enough to bring things back to life.
Hope this help you.
Mar 09, 2014 | eMachines ET1331G-03w
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
I replaced the memory and turned the computer on and no video. no beep either.
Assuming you tried putting the old ram back and had the same result?
No beeps are indicative of a failed Power supply (check the PSU fan is working and the CPU fan is turning), Then check the ram modules are firmly inserted. Check the small 4 pin Black and yellow power rail that powers the cPU is tight.
After that, unplug, remove the CMOS battery, leave for 30 seconds and re-insert, try booting now.
If that fails, you have either got a fault on the mobo, or a dead CPU.
Testing the board with a known good CPU will confirm the latter.
Check the motherboard for blown and bulging capacitors, see if you can smell any burning from the board, either will indicate damage to the motherboard
Feb 12, 2011 | EliteGroup NFORCE 570 SLIT-A Motherboard
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
Just installed a new motherboard model MSI 790FX - GD70 and new ram and cpu to go with it. plugged everything in and check all the connections. When we turn on the computer all the fans start and all the...
check the cable connections initially
Remove the power cord from the cpu
Remove the cmos battery and reset the bios by changing the jumper which is present to reset bios in motherboard.
Place the jumper as if it was present already
Insert cmos battery and switch on the computer
Mar 04, 2010 | MSI 790FX-GD70 AM3 AMD 790FX ATX AMD...
Will not boot
do it only if u r a professional..
it seems probably the system bios hs been flashed or updated in a wrong way..if so, u gotta replace the m/b, itz a permanent failure..though there r some exceptionals..
can replace the faulty bios if identical (supported,make,model n version) is available..
well to b on safe hand..do the following:..
unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..
check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby..
there may b also problem with ur monitor or display adapter, try replacing with a standby..
seek professional assistance of ur system admin/vendor....
Nov 05, 2009 | EliteGroup P4M800PRO-M Motherboard
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Singlle long beep on booting up my Biostar M7NCDPro motherboard with nothing on screen
If you get one continuous beep (Long and Non-Stop)
This could happen if:
1. The Power supply is damaged or bad.
2. The BIOS is corrupted. Try resetting the CMOS using JCMOS1 jumper on the motherboard or remove the battery from the motherboard for 20 minutes. At this point the first thing to try is a different Power Supply to see if the result is better. If the same problem happens with the new power supply, you may need to send the BIOS Chip to local dealer for reprogramming.
If you get one long High Pitched tone that does not stop until you disconnect the power supply:
1. Check if the CPU fan is connected to the JCFAN1 connector.
2. The CPU might be overheated. Change the CPU FAN or check if the CPU fan has proper contact with the CPU. Refer to your manual for CPU installation.
3. Clear CMOS battery (JCMOS1), be sure to set JCMOS1 back to 1-2 position. (See Quick start guide/ user manual for more info on how to clear the CMOS)
4. Make sure the power supply you have on your system supports the M/B specification. Example. If you have a P4 M/B, you need to use an ATX v2.03 specification power supply. (power supply that has an extra 4-pin square connector)
Sep 15, 2008 | Computers & Internet
No display
hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
Jun 10, 2008 | Gateway GT5028 PC Desktop
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
