Question about EZQuest King (K529900) Burner
My KING KC-115C Horizontal metal cutting band saw cuts off track.
My KING KC-115C Horizontal metal cutting band saw does not cut perpendicular to the holding clamp. The blade runs off at an angle to the vertical. Or another way of putting it; the blade does not cut at 90 degrees to the horizontal, but to some lesser angle.
The bearing guides for the blade must be at fault but do not appear to be adjustable.
    Problem Solver:
  • 9 Answers
I used to work for Doall saw company. While I am not familiar with the particular model you have, I have seen issues like it in Doall saws.
Firstly, If bearing guides are not adjustable, replace them. There should be only about a 32 of an inch play between them (in addition to the thickness of the blade). Secondly, for a prodution horizontal bandsaw you should have the blade tensioned a @30,000 psi. Thirdly, if after that, you are still having problems, I would suggest checking the bearings on your drive and idler wheels for runout (in addition to the condition of the tires).
Posted on Jan 28, 2010
How do you lock femi 782xl Bandsaw for vertical operation
BandSaw at Trick-Tools
vansantent.trick-tools.com/tools/BandSaw
BandSaw found in: Femi NG160ABS Benchtop Semi-Auto Mitering Bandsaw, Ellis 1600 Dual Mitering Head ... ...that has a locking valve for setting up cuts. ... The HEM Saw 782XL portable bandsaw is a great fit for hobbyists and those needing an accurate portable ... JET HVBS-56M, 5 x 6 inch Horizontal/Vertical Bandsaw.
Band Saws, Horizontal & Vertical - Trick Tools
www.trick-tools.com > Sawing
Find Band saws in a variety of configurations including horizontal, vertical, ... Bandsawblades are a long lasting and low cost consumable, reducing the maintenance andoperating cost of this type of ... Femi 782XL Benchtop Mitering Bandsaw.
FEMI 782XL Swivel Head Portable Bandsaw 110 volt
www.stakesys.co.uk > Shop By Category > Metal Cutting Band Saw
The 782XL can be locked in a vertical position and, when used in conjunction with the optional table kit and quadrant, used as a vertical bandsaw for cutting ...
' The Saw That Cuts Straight
www.hemsaw.com/
Dec 16, 2015 | Saws
Mbs45 blade undercuts out of square, twist in 2x2 1/8" tubing
I believe Black bull band saw is a Taiwan imported saw. They are even cheaper to HF band saws. This band saw have so many issues; make sure you align the guides, tune it up and use good bi metal band saw blades. I suggest you use the Haltbar 601 bi metal blade. I'm using Haltbar and I'm getting really nice cut.
Jun 18, 2014 | Buffalo Tools Black Bull Metal Cutting...
Amada HA-250 horizontal band saw troubleshooting guide.
You can download free Amada manual on bandsawmanuals.com .
May 30, 2014 | Saws
Cant see m to cut in a straight line. when cutting a wine bottle the top it cutting straight but the bottom it not.
Cutting a glass on band saw is like cutting a metal. You have to make sure that you set up the band saw correctly, get a good quality blade, run on right speed, enough coolant and feed the material nicely.
Oct 21, 2013 | Saws
How do you line the blade on a shopfox m1014 it wont cut stright
You should check your manual for correct blade tracking adjustment. Place the guides properly. You should use a fine
blade as well. I have 7x12 band saw and I am using Haltbar band saw blade on it. I got it on sawblade.com . The blades
are really good.
Mar 27, 2013 | Shop Fox Metal Cutting Band Saw 7in. x...
CAN I USE A SEARS 12 INCH BAND SAW TO CUT MEAT. WHAT TYPE OF BLADE DO I NEED. DO I CUT THE MEAT FROZEN OR NOT?
That will work with the meat frozen or thawed, but the problem will be that the band saw will be very difficult to clean adequately afterwards. That won't be a big problem until a week after you have cut meat with it the first time. Once it stinks you won't want to use it cut anything! A meat-saw is made to be easier to clean than a wood or metal cutting bandsaw.
Dec 10, 2012 | Saws
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
I just bought a Skil Band Saw and it wants to cut to the left (as you look at it) it was being used to cut 16 gauge steel.I just changed the blade.
You probably just need to track the blade, pull all the guides back away from the blade and free wheel it by hand, tilt the blade into the center of the tires, if it doesn't center on both, one of them is off. When it centers, torque it up a little, then adjust the guides to the blade, don't push the blade out, just barely touch it, then it should track and cut straight. Good luck. Does this machine have a transmission for metal cutting? Or just one speed?
Feb 01, 2010 | Skil Saws
Problems with my band saw bs100
Look for any gouges in the metal surface that have metal projecting above the milled surface. Also, file or grind away any sharp edges along the miter gauge track. If the cut surface is very irregular, the blade may have overly coarse teeth, or the blade guide rollers may not be holding the blade firmly allowing the blade to wander while cutting. Hope this helps.
Jun 27, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
EZQuest King (K529900) Burner Logo
371 people viewed this question
Top EZQuest Computers & Internet Experts
David Payne
David Payne
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
