Question about Ovens
I have a Magic Chef stove Model # 31001SAW. It is made by Maytag.I need to replace the ignitor switch in the oven. The light(flame) comes on but the gas does not ignite. I am assuming that the ignitor switch is the problem. Help!
    Sergeant:
    Champion:
  • 289 Answers
If the ignitor is not a brite red than it is not putting out the 3.5 amp's neaded to open valve.you can check the valve with a continueaty meter.remove the two wire's from the valve and check valve with meter,if valve check's good than ignitor is bad.
Posted on Nov 18, 2009
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
I have a magic chef ovan/mic unit, when I press the bake option and set the temp the igniter goes on but the gas does not kick in. model # 54FN-5TKVWM
even though the ignitor glows it doesn't mean it's good it opens the gas valve by amps not just because it glows,if you turn on the stove and when you see it glow if the flame doesn't ignite within 40 to 50 seconds you have a bad ignitor.if you leave it alone for a few minutes does the flame ignite?the only other thing it could be is a bad gas valve but most likely it will be the ignitor
Sep 25, 2011 | Magic Chef Ovens
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 06, 2011 | Magic Chef Ovens
Our Magic Chef oven 31001saw will not warm up at all. The stove top works, the gas is getting thru. What is wrong?
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 18, 2010 | Magic Chef Ovens
Replaced bad thermostat on Magic Chef model 9112xpb. Ignitor now glows orange but oven still won't start. Does gas valve on bottom of oven need to point up or sideways to start?
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
May 16, 2010 | Magic Chef Ovens
My stove does not ignite even when glow light is on model 3127wtv
Turn off the gas supply to the range. Remove the oven racks,oven base pan,flame spreader.
Place a clamp on amp meter on one wire of the ignitor and turn the oven on to BAKE. When the ignitor glows it should read more than 3 amps. If it reads 3 amps or less replace the ignitor.
Jan 03, 2010 | Magic Chef Ovens
I have a Magic Chef Chateau Gas range. The upper oven does not heat properly. It comes on, but never gets up to operating temps.
you could have a bad ignitor check that it is actually igniting the gas and you can see flame, also check the cavity sensor a probe that sticks into the oven at the top usually on the left top corner but if the bake cycle works with good results them it is ok
check for flame when it starts give it a mibute to ignite, if it does not then you need to replace the broil ignitor.
Sep 19, 2009 | Ovens
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Ovens Logo
227 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
