Question about Whirlpool Duet GHW9150P Front Load Washer
;light on left stating control locked and cannot get it to do anything. It did not wring out clothes
    President:
  • 744 Answers
Hello, hit and hold the volume button for 5 seconds. Mike
Posted on Nov 18, 2009
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Nov 23, 2015 | Washing Machines
Door does not lock when set to self clean. Why?
HI. This will occur if the door lock mechanism is malfunctioning. This could be because of a failed connection, due to welded contacts, or a separated wring harness at the mechanism, or control board. Check these areas for faults. replace the door lock mechanism if all areas stated are ok, and connected well.
Oct 24, 2009 | Bosch HBL 755 Stainless Steel Electric...
My clothes will not spin to wring out the water
Clutch is bad, Control Panel Bad, or Motor Control Board bad. Usually the clutch you can get a new clutch online fron an appliance parts dealer there are several so shop around. INSIDE THE BACK COVER IS THE OWNERS MANUAL remove a few screws and get it. This will help aid you in self repair of MAYTAG :( I finally gave up and bought an old standard machine and I have no worries or problems with my washing machine, no stinky drum or clothes, no break downs, and no half washes. I ll never buy another high end washer set again, never.
Oct 13, 2009 | Washing Machines
Door is locking but machine will not execute spin cycle
My washer is draining the tub but it's not spinning .Would this be minor or should i buy a new one.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
My washing machine agaitates to wash the clothes but it does not spin to wring out the clothes at the end of the cycle it just stops. I dont know why it does this the washer is only 2 years old. As a...
Dear Customer,
I recommend you to follow the below stated routines
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • And as for the clothes being wet after the spin..This may be a spin problem or a drain problem
    Drain:
    • Make sure the drain line is clear
    • Check the drain hose for a partial blockage
    • Inspect the water pump
    Spin:
    • Test the motor
    Please rate this Solution.. Thank You.. Good Luck..
    Nov 26, 2006 | Avanti W789SA Top Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    21 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
