Question about Samsung 40 in. Flat-Panel LCD HDTV
Samsung 40 inch LCD takes longer and longer to turn on, 5 minutes now, screen black with light under name on; once on line defects appear on screen. Sometimes when turns on only random lines instead of picture. Once on picture otherwise ok. Noises present during turning on process also. Thank you.
  • 834 Answers
Common problem you have a bad cap or 2 in your power board this board is the one where tour ac cord plug into these can like caps will be puffed up on top the values are written on the sides on the device replace them and your good to go
Posted on Nov 18, 2009
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Audio is OK, Video NO
It sounds by the description that your tv has a defective T-CON (Timing Control) Board -this is evident by the 5 flashes and the fact that the screen was working ok, then going black then repeating.
The board can be bought usually on ebay but, only if you feel comfortable in replacing it yourself, otherwise a sony service tech needs to be called to repair this!
Good Luck
Rich lilja
Dec 15, 2013 | Sony KDL40EX710 40 inch BRAVIA 1080p LCD...
Sony KDL40EX710 40 inch BRAVIA. The audio is good, but the image appears only every 2 or 3 minutes, then the screen turns green or black. After 5 minutes the image appears again for 2 or 3 minutes and the...
It has an internal electronic problem where some component is getting warm and then failing, until it cools down again.
If you are confident with electronics you could open it up and identify the failing component while it is running, by using freezer spray........
My screen began to take longer and longer to come on in the morning, up to 5 minutes. Then throught the day if my computer went on standby power, it would take 2-3 minutes to come back up..(and both ways...
kvons, Your monitor's behavior common to all brands not just Samsung. May need servicing by electronic technician. Read my and other tech's FIXYA profiles about solutions to BLACK screen problems and the two most common failure modes. 12fixlouie
Feb 04, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 40 inch lcd screen goes black just got sound
most likely the main board is defective but it could also be the lcd panel itself or the lvds cable.probably will need a service call to determine problem.
Oct 28, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Samsung 40" 1080P power flux
Try to replace the Power Supply board first.
Feb 01, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung 40 in. Flat-Panel LCD HDTV Logo
209 people viewed this question
Jerry Greenberg
Jerry Greenberg
