Remove the little plastic lens and throw it away. There is no replacement available anyway. Reassemble the tv and it should work fine. Mine has been good for quite a while now.
Could be as simple as a burned-out lamp, but flashing buttons on the panel mean that it's trying to tell you something's broken, so it might not be just the lamp.
You, sir (mam?), need a manual, or somebody who has one. I do, but it's at home. Perhaps if you responded with how many times the lights flash, I could look it up...
there is a menu setting for best pix or longer lamp life.
Also, turn up brightness of picture settings(different menu)
Also use daylight setting, vibrant, (different menu).
Bulbs dim over time and dust can accumulate on projector lens, mirrors and (not so much on mine) back of screen.
New lamps tend to melt a plastic lens in light engine, a dark shadow may start to appear upper left or center. this started to happen to me with new bulb, (Ebay O.E.M. supposedly $114). I switched back to original lamp hopefully to slow the burn till I can tacklle a repair. Take a look at this website. Hope that helps. http://www.61md10.org/modules/newbb/viewtopic.php?post_id=2651
If it's agreen wire with a stripe (usually yellow) it is likely a chassis ground (ie center plug of 3 prong electrical cord). The best source for schematics I've found (although they cost) is servivcemanuals.net.
Hope this helps.
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
