Question about Thermador Cooktops
Burner will not light even though the igniter is sparking.
Oven gets to hot. things burn in half the time.
Posted on Nov 20, 2009
  • 619 Answers
SOURCE: Ignitors continue to ignite on other burners
the igniter switch are stuck /need clean contactor of the igniter .
Posted on Jan 10, 2008
Drummernick
  • 440 Answers
SOURCE: no ignition on one of my burners
u got gas going to them or dirty vales
Posted on Feb 03, 2008
  • 222 Answers
SOURCE: kitchen gas 4 burner cooktop
i think all igniter switch are grounded,i request to call expert technician to repair it, or uf u want u open the cooktop to see the igniter swicth at konb control area,clean one by one using thinner,remember switc off the plug first.
Posted on Aug 10, 2008
  • 2976 Answers
SOURCE: four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Posted on Jan 04, 2009
  • 10865 Answers
SOURCE: I have a GE Profile
the ignitor switch for that particular burner is stuck in the on position. I may have some debris in it which is causing the problem. you could try to clean it using a blast of air from a keyboard air cleaner aerosol can, available at any office supply but most likely you will have to replace it.
Posted on Aug 17, 2009
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
My gas cooktop is contiuing a clicking sound to start the gas burner. it is not the color of the flame or that stuff. Just the starter keeps trying to start. the gas burner that is all. Blair
Hello Blair
Does the clicking or spark stop with all knobs in off position? If so it's probably the one burner valve for the one you're trying to light ,stuck in light mode,sending signal to module.Have that burner valve replaced.($50). (2) If clicking continues even though everything is off, it could be any one of the burner valves or your ignition module is messed up .You would have to pull wire off each burner valve one by one to find the offending valve . If not valves then suspect ignition module.
Easily fixed either way.
Feedback appreciated !
Aug 03, 2011 | GE Cooktops
Igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Burner won't light
is gas comeing out of the hole? sometimes by cleaning the orfice hole (food and debrie will get in there and plug the hole not letting the gas come through) i get a needle and poke it.
when you say it is sparking...When you turn the dial for that specific one you want ignited... That one is sparking? If so Great. This means you either have a plug or the valve is bad and not letting the gas flow through.
Apr 04, 2009 | Amana AKS3040 Gas Cooktop
Four burner gas hob
Jan 04, 2009 | Cooktops
Kitchen gas 4 burner cooktop
Aug 03, 2008 | KitchenAid 31 in. KECS100 Electric Cooktop
Jan 08, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Cooktops Logo
100 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
