Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher fills with dirty water after finish
Bosch shv55mo3gb
the machine fills with dirty water after completing washing and drying whether left on or switched off. eventually it overflows.
any suggestions please
  • Anonymous Mar 12, 2014
    After finishing its wash the machine stays hot to the touch at the side and sometimes hasn't completely dried the pots
    Genius:
  • 1,003 Answers
CHECK TIMER AND WATER OULET SOLENOID
Posted on Jan 18, 2008
6ya staff
SOURCE:
My Bosch classixx washing machine is overflowing
Bad water pressure switch or bad water inlet valve? does it have or leak water in the tub when not in use? ( inlet valve) sometimes the pressure switch tube has a hole or blockage in it and will not have the pressure needed to open diaphram and go into wash cycle and it may overflow
Mar 09, 2015 | Bosch Washing Machines
I have gritty debris on the dishes, it appears the small bits left on the dishes before loading get broken down and rinsed onto them as grit again! The dishes are not spotless going in but they are scraped...
1. it can be water backing upfrom maybe a garbage disposer like a clog ,or fill jet dry compartment completely.add nad fill then open and close the door 3 times then you will be able to add more what you are doing is taking out the air in the dispenser.once it is filled completely last thing is to make sure the water ghoing into machine is hot,then start the machine for best results. let me know if i have been of some help
Feb 24, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
Sirs: The Softener Dispenser on my Bosch Axxis washing machine is filled up with water. What to do? It won't dispense softener.
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK then try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spray will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Nov 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
313 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
