Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Picture tilted? - Mitsubishi WD-62525 62" Rear Projection HDTV
  • 456 Answers
If you have moved the tv or had the lamp replaced it could be that the lamp is mis-aimed and thats the reason the picture could be tilted. Good Luck.
Posted on Nov 18, 2009
KDS-R70XBR2 Tilt
First is make sure where you have it positioned now the Entire base is supported and the ends of the set are not pulling down on the cabinet--other than that set may have in the menu a tilt adjustment--there will also be a manual one but only an expert should tamper with that---try again if tilted to lift up on side of cabinet that is tilted down
Apr 19, 2012 | Sony KDS-R70XBR2 70" Television
Picture is slightly angled on my 73 inch dlp.
I would suggest two possible reasons: first the mechanical adjustments are off or out for tilt----rare but can happen.
The most common reason for this is the set is not sitting completely on a flat stable surface; if one side or both are not on a perfectly flat surface the picture will tilt; you can always see this effect if you grasp one side of the set and pull up/down and or twist the cabinet a little.
The set may (a few models do) have a tilt adjustment in the customer menu.
The mechanical adjust should only be attempted after the other possible causes are ruled out.
Let me know if you have questions.
SDT
Nov 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
My Sansui SY-21-Eye TV is not showing picture is not horizontal. It is tilted with a little black line on top. I mean the whole picture is little tilted with a black line on top and on bottom some part...
I too had the same problem but i have solved it. When i was scrolling all the channels, a hidden menu appeared. In that hidden menu all the tv functions are present. By changing the values we can adjust the resolution.
Feb 26, 2011 | Televison & Video
Since replacing the bulb, it seems that my picture is tilted to the right about 1/2 inch or so. A local repair shop says the bulb has nothing to do with my problem. Any suggestions on correcting this...
I have the same problem, and all I did was replace the bulb and housing the picture is not a true horizontal, the picture is tilted to the right....Any ideas>>??
Jan 22, 2011 | Mitsubishi WD62628 62" Projection HDTV
Picture is slightly tilted
Its an easy adjustment but it requires you to work around the deflection yoke on the neck of the picture tube. Above the yoke is a red connector that is carrying 30,000 volts then on the yoke itself you have wires that are connected to the horizontal and vertical circuits that can carry up to a 1200 volt pulse. So this alignment is not for anyone but a technician. I personally would leave the tilt until you can have a technician touch it up for you. Take a moment to rate my answer. Thanks...
Nov 20, 2009 | JVC AV-32FA54 32" TV
What is your opinion about the Craig 15'' high definition LCD TV? Is it discontinued? Is it a decent TV?
I purchased Craig CLC501 from CVS and I am very satisfied. The picture and sound are great. There are many adjustments through a menu but you also can change settings with dedicated buttons on the remote. You can add and delete channels for easy channel surfing. The tuner does a good job picking up week signals with an antenna. It has a QAM tuner for HD channels on cable systems. The inputs on the rear are HDMI, YPbPr, S-VIDEO, VIDEO, RCA AUDIO R/L, PCAUDIO, VGA Port. It has a headset output jack that can be used for external speakers. The 12 volt input accepts the universal power supply for use in an auto.
Oct 13, 2009 | Televison & Video
Mitsubishi WD 62725 -picture slightly tilted from right to left
Thats a common adjustment called the TILT adjustment. You can get the service manual emailed to you from the following link which will explain how to doo the Tilt adjustment. Heres a link to the proper manual for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/wd52525-dlp/cName/mitsubishi
Jul 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Skewed picture
Convergence problem.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Televison & Video
Tilted pictures
First you should verify your findings by taking some photos with the camera sitting on a level surface. Check for level while viewing through the viewfinder and also while viewing the LCD screen on the back of the camera. When you are sure that everything looks level, take several pictures. If the pictures are out of plumb, something inside the camera has shifted. This is not fixable by you. The camera should still be under warranty. When you send the camera for warranty repair, be sure to print the pictures and include them with the camera. You might first check to see if you can still return it to the store where you made the purchase (take along the purchase receipt). Let them see the pictures.
Sep 06, 2005 | Olympus Camedia C-350 Digital Camera
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
