Question about Westinghouse Washing Machines
Not emptying water - Westinghouse Washing Machines
  • 103 Answers
Drain pump might be faulty.
Posted on Nov 18, 2009
Do you empty the water out of the base before next use?
You may not have to, unless the water shows some dirt residues in there. If you need to empty it out, use a shop vacuum.
Jan 23, 2016 | Humidifiers
How do I get the bleach dispenser to empty?
Most of these dispensers are of the syphon empty variety. If it's got water in it, it's got water in it.
Feb 19, 2015 | Washing Machines
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
It is not draining the water out it is a haier hw-c1460tveme-0
Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
Feb 12, 2011 | Washing Machines
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
Says 'empty water' but empty - leave to cool and works again for 30 minutes?
Might be a faulty water level sensor or it could be the sensor has some fabric softener on it.
May 19, 2009 | Dryers
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Harjeet Singh
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
