Question about Pioneer DEH-P2000 CD Player
Settings I am having trouble setting my settings on this car stereo.As far as front and baack speakers the whole thing.can anyone help me
  • Anonymous Jan 11, 2008
    I am still having trouble stting the settings on my car stereo.It is a pioneer DEH-1000 Supertuner3.Same as above pic.Getting to set the speakers and everything.I did get help with the clock.Can anyone help me with this????Thanks
  • Anonymous Jan 19, 2008
    Pioneer DEH-1000 super tuner 3.I was givin this new car stereo and had it installed in my car.I have figured out how to set the clock but can not figure out how to set the settings as far as the front and back speakers .Can anyone help me with this.They did not have the manual book to give me .My speakers are only playing on the right side..Im getting frustrated with this whole thing.HELP!!!!!!
Wha? have you tried pressing audio and pressing left when the screen "fade" or "balance" pop up? (note - fade and balance are in the same category, in "audio".
Posted on Jan 28, 2008
6ya staff
SOURCE:
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
How ot hook up speakers on this amp/
As far as I know, your sound will drastically improve if you run them +- and +-. Connect the one speaker correctly (+-) and then with the music still playing, try swapping the wires on the other speaker around and see which sounds better + to + or + to -
Hope this helps
May 20, 2010 | Volfenhag ZX-8300 Car Audio Amplifier
Looking for a diagram/schematic for the stereo wiring, so i can reinstall my new cd/stereo player
I hope this would help you: 1999 Chevrolet Silverado C1500 Car Stereo Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Feb 12, 2010 | 1999 Chevrolet Silverado 1500
Sony str d-1015 stereo receiver stopped working
if you have been blasting it, that could be why, recievers of this era are made with cheaper parts that cant handle what theyre supposed too,
i dont know specifically, but things like that have some sort of auto fuse...
i would assume, you are using it with wrong ohmage speakers, are you using car speakers? car subs? older speakers?
most home stereo equipment is 8 ohms, i have a set of 140 watt 3 way (10"[vented]/4"/2") as fronts and a set of 80 watt rears (6"[vented]/1.5"/24mm) the fronts are induviduals, meaning they have to be bought individually, and are not sold as a set, or part of anything, the rears were part of a bookshelf system, i got the set secondhand... but i always checked the ohmage...
Jan 08, 2010 | Sony STR-D1015
I have a 1995 saturn sc1 and im having trouble finding the stereo color codes for it without buying them somewhere
Hello! Here you go!
Hope this helps!
-KC GTO Dad
Sep 18, 2009 | 1995 Saturn Sc
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
I just need to know if the 2 channels from the amp go to the front or rear speaker location on the stereo and if they go to the rear do I hook up the rear speakers directly to the amp and the fronts to the...
The only thing that hooks to the stereo are a remote cable should be labeles on the amp. and the rca cables (red and whites) the different channels go to different sets of speakers.right to right left to left. make sure your amp is grounded well or you'll throw the fuse. Hope this helps if you have questions contact me.
Mar 08, 2009 | Sony NTX-2135 DHD 2 Channel Car Amplifier...
JVC RX6040 OVERLOAD TROUBLE
clean your volume control if that does not help take it to a tech for repairs.
Mar 29, 2007 | JVC RX-6040 Receiver
Denon AVR-2106 troubles
If the surround back is turned on,on the receiver,then the 7CH stereo will activate the 2 rear,but if it's off on the receiver the 5CH on the remote will do the same. I don't know much about the unit changing from 7CH to game,rock Arena etc.that i know will happen if u press the DSP simulation found @ the 3rd. top right button on the remote.
Jan 16, 2007 | Denon AVR-2106 Receiver
Pioneer DEH-P2000 CD Player Logo
192 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
