Question about Car Audio & Video
I have a sony car stereo and lost the harness so i wanted to make another one for it so i need each pin color in order the model# is br-5735 its 14pin
  • sdjayo Nov 18, 2009
    do u got the diagram
  • 3,051 Answers
Hello there: i have a sony car - new-harness.jpg adapter.jpg This is the wiring harness that comes with the car stereo. All of the wires are identified in the manual that comes with the radio. Although it could have been wired directly to the wires sticking out of the dash, I chose to connect to an aftermarket harness that plugs into the connetors that were made for the factory car stereo. The easiest way to wire up a stereo is to buy a wiring harness that connects directly to the existing factory cable assemblies. The harness comes with a wiring diagram explaining what each wire is used for. Notice that this vehicle requires a set of two harnesses and they come in one package. There are two plugs on each harness making these a "universal" fit for a wide range of Ford/Mercury vehicles. If you purchase these adapters, you won't have to cut off the factory connectors on the vehicle. It will be a snap to re-install the factory radio!
Posted on Nov 18, 2009
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
95 s10 blazer 6 speaker stereo what are speaker wire colors harness was cut 6 speaker not 4 ..dash .front door . Back door
This year never came with 6 speakers (4), so what wiring is installed for those 2 add on speakers I would have no idea.
Here is the factory wire colors from the manual.
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 07, 2016 | Cars & Trucks
The wires are a different color on the new speed sensor conector
i guess you dont know that only the main harness colors are standard (jeep) Jeep does no dictate sensor wires.
if the sensor has pig tail wire they are not standard colors. (only pinout matters)
just like the oxygen senors made by all companies.
the sensors are made by many a company and the colors are not standard. only the pin plug are standard.!!! a fact.
see?
why not just plug it in, like it was day one.
my guess, is you dont know the fact above and are worried only?
or is the connector harness all hacked to H3LL. (not stated)
92 wrangler.
NO ENGINE STATED, so we can really help , see?
a/t or m/t trans, 4wd or 2wd?
answering for rear VSS sensor on YJ (tail shaft speed is what it really is, no matter if 2wd or 4wd its rear sensor.
YJ jeep
it is.
I have the books.
chapter 8w covers all wiring.
ill post the pins. now. for VSS it just plugs in, why are you worried.?
pdf page 69
page YJ-12 actual
free book is here 93, (same)
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
it just plugs in.....
Jun 20, 2015 | 1992 Jeep Wrangler
I have a toyota trueno 1992 and i want to put a new stereo in it
Go to the auto parts store and get a wire adaptor made for a 1992 trueno. It will plug into your factory harness. The wire colors are prematched to your sony and other aftermarket stereos. Just match the wire colors, splice with connectors making sure no wires are exposed. (A little electrical tape for good measure around splices helps). Then it just plugs in. If your factory stereo has mounts that screw onto the radio, unscrew them and attach them to the sony. Remove sleeve from radio and discard. The screw holes are already on the sony.
Dec 29, 2012 | Cars & Trucks
I HAVE A 12 PIN CONSOLE WIRING HARNESS UNDER DASH TO HOOK UP ALL THE GUAGES COLORS ARE AS FOLOWED PIN 12 BLUE 1DK BR 10TAN 9 BABY BL 8BL WITH WHITE STRIP 7 PINK 1LT BR 2 GREEN 3GREY HOW WOOD I HOOK THEM UP...
mcdevito75 here, I would simply compare the pins on the new dash with the old dash. Or compare the new wireing harness with the old, compare the wires at the connector itself, compare both connectors the new harness and old.
Jul 16, 2010 | Mattel Hot Wheels Color Shifters Car '67...
Car stereo harness of my 1994 hyundai accent
NOW,FIRST YOU HAVE TO GET A WIRE HARNESS FOR YOUR MAKE AND MODEL FROM BEST BUY OR CIRCUIT CITY.THEN ALL YOU DO IS MATCH UP COLOR TO COLOR.
Jun 07, 2009 | Car Audio & Video
I want to take out factory radio to install stereo
Stereo dealers have wire harness adapters for almost every make and model of car. It will come with a connector both with color coded pigtails that are usually prestripped. The package will described which wires go where and their color codes. The deck you bought should have a pigtail with color coded wires and they'll match up to the ones on the harness adapter for your car.
After connecting them all properly, you can take your deck with the attached pigtail and plug adapter and plug it directly into your car stereo plug where your old radio was connected...don't forget the anntenna lead as well... Not to difficult...email if you get stuck...
KEN
May 08, 2009 | Sony Car Audio & Video
Connection diagram for XR-CA300 SONY car stereo
Hello eliasrvc2,
Sony's support site shows the color codes for wiring both a 9-pin and a 16-pin harness. Click the appropriate harness to bring up the color code table.
Hope this helps.
May 05, 2009 | Sony XR-CA300 Cassette Player
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
