Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Need schematics for honeywell s861ou3009
Need schematics for honeywell s861ou3009 universal replacement intermittent pilot mode where do the th/tr tr th go on the module what is tr/th tr th?
  • GE Master
  • 43,501 Answers
Those terminals are the power to the module. The tr should be the 24v (hot) line coming from the transformer. The tr/th is the common from the transformer and the th is the 24v line coming back from the t-stat. So tr stands for transformer. the th stands for thermostat. And the th/tr is the common.
I know you ask for schematics but I felt that I could easily explain it to you. It really isn't all that hard. In some cases the tr does not need to be hookup. if you only have two wires there than just hookup the th/tr and the th and it will work.
Posted on Nov 18, 2009
I need the wire drawings to change from the Johnson G770, or the Fenwal 35-63J To the Honewell S8610U Universal intermittent gas ignition control.
Hello. I've attached multiple schematic diagrams for different configurations of this control. I hope one of the pix helps you delineate the different connections. The last several schematics were too large for a single screenshot so there are 2 pix for each of those schematics.
Sep 16, 2015 | Honeywell S8610U3009 Universal...
Keep replacing control
Check to see if anything on the low voltage circuit is stealing voltage ie gas valve...make sure you have the proper low voltage to the ignition module (check the transformer)
Nov 22, 2013 | Honeywell S8610U3009 Universal...
Trying to replace ingnition moduel for an older goodman furnace b13707-24 need to match up wiring
There are many types of modules on the market out there. If you are replacing one for a standing pilot, you will need to but a retrofit kit. On most modules, you just take the wire from the old one that is marked such as MV for gas valve, PV for pilot valve, 24v Hot, Common, Flame sensor, If it has TR for thermostat, you will use that in place of the 24 volt hot as you don't want to run 2 -24 volt connections to the module.So, you will have commons, more then one so tie them together, pv, mv, fs, tr or th, 24 V. If you can give me more info on the module you are replacing, and what you are replacing it with, I can tell you exactly how to wire it.
Sincerely, Shastalaker7
Feb 16, 2011 | Heating & Cooling
The fan will blow but not in heat mode. The gas heater sounds like it wants to work but there is no heat.
Hello my name is Heath it will be my pleasure to assist you. The problem is probably with the ignition. Check the pilot if its a standing pilot or the hot surface ignitor if it has a HSI ignition If you ohm the hotsurface ignitor and it doesn't show resistance the HSI is shot. If its a standing pilot try lighting the pilot if it lites and doesn't stay lit then the thermocouple could be bad its the rod that sits in the pilot flame easily replaced with a universal replacement that can be found at most hardware stores.
Apr 25, 2010 | Honeywell Programmable Thermostat Heater
I got a new honeywell gas valve for my furnace,but instead of three wire conector it came with two,tr and th,intead of th-tr,and tr,th.how should I conect the wires from the 24 volt transformer and...
Take the hot wire from the transformer to the R on the t-stat... then take a wire from the W on the t-stat to the th on the gas valve... then take a wire from the tr on the gas valve to the common on the transformer.
That's all there is to it!! :-)
heatman101
Apr 16, 2010 | Heating & Cooling
Intermittent Pilot ignition control not sparking
Check it by arcing it to ground. Replace it with a universal control if bad. Honeywell makes one that will work, check out specs on the S8610U module.
Jan 15, 2010 | Weather King 10AJA4801AH Air Conditioner
The pilot will not stay lit on my GWN20T. Have tried cleaning with compressed air. Would this be the thermocouple? If so can I replace with a universal unit? Lowes has a Honeywell 24' for a 30millivolt....
if the pilot stays lit while you hold down the nob and goes out when you let up on it then you need to replace the thermocoulpe and yes thye honeywell will work.
Nov 27, 2009 | Desa International GWN20T Heater
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
303 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
