Question about LG Flatron L1751S-SN 17" Flat Panel LCD Monitor
Flat Screen L196WTQ hook up to MAC
I have a new L196WTQ flat screen monitor. It is hooiked up to my MAC. I can't run the CD. Is there MAC compatible software?
2 Suggested Answers
  • 11361 Answers
SOURCE: LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps:
Posted on Jan 26, 2010
  • 1684 Answers
SOURCE: LG Monitor L196WTQ when computer shuts or turns off
You have a power supply in the monitor that is about to fail. Check out his article on our web site about repairing this model - If you can solder then you should be able to do the repair yourself. It involves replacing 6 small parts. If you don't want to do the repair yourself we do offer a repair service for $30 plus shipping. Let us know if you have any questions about the repair or the repair guide.
I hope this helps, if so please rate our solution.
Corporate Computer
Posted on Feb 19, 2010
0 characters
1 Points
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
My Brother is trying to connect to HP Pavillion XT914. A friend connected her flat screen to his pavillion to help him delete unwanted files and he can't get the monitor to work any more. How do we get his...
It might be that the screen resolution set on the pc is too high for the monitor to display.
try hooking up the flat panel monitor again. (CRTs can have a flat screen as well)
lower the screen resolution to 1024 X 768 pixels click save.
hook up the other monitor to see if that was the problem.
If you can get the monitors menu to come up on the monitor try setting it to factory defaults.
If no luck, does the monitor work on another PC?
Let me know if this helps you or not.
Thank you
Feb 05, 2011 | HP Compaq FS7600 17" CRT Monitor
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Cant use my rad 5 with a desktop Dell computer with Vista
Temporarily connect another monitor to your computer.
Set the screen-resolution to 800 by 600 at 60 Hertz.
Disconnect the other monitor, and connect your RAD.
It should display.
Try changing the screen-resolution to 1024 by 768, and "test" it.
Jan 04, 2010 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Grey screen
First, you need to eliminate the video card or the Kogi as the problem, which is quite easy to do by testing a known working monitor on the Matrox card.
Jan 26, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Monitor clinks off and on(black screen)
I would start up in safe mode, and disable that driver. It sounds like it is a bad driver on your new pc. Then turn off the pc, hook up your new monitor and start up fresh. Your pc should automatically find the best compatible driver for you. If this won't do, can you please list the driver you did use? Maybe we can search for another one that would be compatible with your model monitor.
Oct 27, 2007 | HP Pavilion F1703 17" LCD Monitor
LG Flatron L1751S-SN 17" Flat Panel LCD Monitor Logo
61 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
