Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Replaced color wheel on samsung dlp Color can't be adjusted
Replaced color wheel on samsung dlp Noises have stopped but the color is blue and it can't be adjusted what to do?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Some of these sets have a jumper plug that has to be removed when you install the newer type of color wheel.
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Posted on Nov 18, 2009
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLN467W
This tv have a colors wheel.Now ur tv colors wheel it dead.The colors wheel is dead,no colors black&white,loud squiling noises,loud motor noises.All indication of the colors wheel is dead,spinning off of is axis,not function anymore.Hire a tv tech.for this.Not machanically incline,don't atemp to change the colors wheel ur selp.
Jul 12, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
Oct 30, 2009 | Samsung HL-R4667W Rear Projection...
Samsung 50 DLP is making a grinding noise. No Picture,
sounds like the color wheel. If you replace the color wheel you will be good.
Apr 23, 2009 | Samsung 50" Slim-Depth DLP HDTV
Adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Mar 21, 2009 | Samsung HL-R4667W Rear Projection...
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Color problem
Samsung color wheel fix
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
452 people viewed this question
Henry  Thomas
Henry Thomas
