Question about Dryers
The buttons which supply the different power levels will not stay down
Your members supplied the answer which is to replace the whole button part, however, the buttons cannot be accessed.
Posted on Nov 18, 2009
Testimonial: "Thank you, however I worked that out myself. What a waste.A perfectly working $120.00 fan which won't stay on"
Light on bottom just stay red
I have a new power supply and my light stay solid red on my LG tv. Has anyone experienced this. I ordered the power supply from Sears. Someone please help a brother.
Nov 20, 2014 | LG 32LD550 32 in. LCD HDTV
POWERS OFF BY IT'S SELF
Hello FixYa customer,
There can be different issues in the mechanism or electrical that will cause the unit to shut down. However, since the power is going off completely after the initial plug in I suspect the power supply.
The SMPS, Switch Mode Power Supply has filter components that age due to heat, the voltage output on the filters reduces until the Micro Processor malfunctions and the unit won't stay on. The power supply filters can be changed by an experienced technician for $10-$15.00 in parts plus labor.
Thank you
Apr 23, 2010 | Sony SLV-R1000 S-VHS VCR
WINDOWS NOT SHUTTING DOWN COMPLETELY
dude i think its the BIOS prob try reseting the bios u can do so by removing the maotherboard battary for one min aand then replacing it this will surely rester the bios.this should it
Feb 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
You will need to enable the Advance power management in Bios and on windows..
Try to see in the bios the advance setting for APM.
Some motherboard you have to enable this.
Other its simply on windows.
After the installation of windows
Go >Right click desktop>properties>then select screen saver tab>below click power>
Then click APM tab
enable and restart
May be this can solve this issues.
Or else I would advice to change the power supply and see.
Regards
uttam
Feb 03, 2010 | Computers & Internet
P4 PC with Antec power supply won't start when cold
I haven't heard of a sensor that keeps it from starting when too cold. Usually in electronics, if it is a cold problem, there is a cold solder joint somewhere. When you apply heat, the joint solder expands enough to make contact and once electricity is flowing, the joint stays heated due to the resistance provided by the cold joint. Since the heat is applied to the power supply, I would say that the power supply is the problem again. If the power supply is still under warranty, I would exchange it or get my money back and go with a different name brand since you've experienced power supply problems with another model.
Dec 19, 2009 | Computers & Internet
WD52527 - Device button doesn't work and causes TV to reset
There is a first step to take in the power supply. (a couple of capacitors could be dry).
The areas where this power is feed is really diverse. But as a general rule the power supply cannot be faulty if we expect all microprocessors working steady and fast.
as as second step i would think in the area related with the video processing who escalates different resolutions as you request a different source of video this requires a fastest microprocessor answer making the rot program go to this default screen when not answer is given.
As you can see this problem requires a repair level component. there is not a user's menu process to do. A visit to the work shop is needed
Feb 06, 2009 | Mitsubishi WD52527 52" Projection HDTV
DONTKNOW WHAT TO DO
Your monitor need repair. Sounds like a power supply problem. The power supply is shutting down due to an overload.
Lou
Aug 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
