Question about HP Office Equipment & Supplies
Want to print avery 5125 labels, printer not trying to feed label page through manual tray?
freetek
  • 5568 Answers
SOURCE: Okidata - label printing alignment
You might try setting up Word for a 'custom' label since it offers that option.
I've done some strange labels by directing Word via that feature.
Posted on Aug 26, 2008
The solution posted did not work for my problem. Thanks for trying.
Posted on Oct 02, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
SOURCE: Zebra LP 2844 label printer
we had the same problem and called tech support. they had us adjust th "Q" and "q" commands and this helped
Posted on Aug 01, 2009
sflummox
  • 73 Answers
SOURCE: cannot print avery labels,
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Posted on Jun 25, 2010
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
Set up a mail merge for labels avery L7162, but the printer prints them a different size - Printer is HP M3035. It is something not set up on the printer
You will need to feed these through the manual tray and you should set the paper size and type to match this label. The avery site shows this as an A4 label sheet. If you are in North America the default on this printer is letter size not A4.You should also ensure that you have configured the print driver correctly when you go to print.
May 23, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
I have an HP Laser Jet 2100 and am having problems printing the Avery 5895 Name Badges. The badges have a new design which allows them to pop off the page way too easy and when they are in the printer,...
One has to assume that you are using the manual feed tray (tray 1) to print the labels.
Give Avery a call and let them know what's happening.
In the meantime start using compatible labels from another manufacturer.
Just a thought....you didn't say where the labels are being pulled off the sheet.
If it is at the fuser you can use the rear output bin which gives a straight path thru the printer.
Feb 17, 2011 | HP Office Equipment & Supplies
How do I feed an AVERY label 5453 into the printer?
Just place the sheet of labels in the paper tray.
You may need to place the labels face down in the paper tray so the prints on the correct side of the labels. If it didn't print on the correct side of the labels then place the labels face up.
Jan 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark won't print on Avery labels
The printer is expecting the label stock to be loaded into the manual feed tray, not the regular paper tray. If it does not sense anything in the manual feed tray it will not continue. If you are loading the stock in the tray, it may need to be pushed further into the try to trigger the sensor.
Jul 05, 2009 | HP LaserJet 4650 Color Printer
Printing LABELS...print out is not centered
there are paper guides on either side of the paper in the bypass... make sure thy are nice and snug right next to the paper...
Mar 26, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
213 people viewed this question
Seeker5211
Seeker5211
