Question about HP Deskjet 3915 InkJet Printer
I don't have a cd on my computer and can't install my printer. The computer is older. It runs windows XP. I'm not real computer savvy.
    Sergeant:
  • HP Expert
  • 424 Answers
Alternative driver download link: HP Deskjet 3915 Color Inkjet Printer Driver
Posted on Feb 03, 2010
    Problem Solver:
  • 10 Answers
Download and install these drivers:
http://www.nodevice.com/driver/Deskjet_3915/get39111.html
Posted on Nov 18, 2009
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
Dec 24, 2011 | Broderbund American Greetings Creatacard...
Windows 7 will not recognize my v6upl scanner which worked in Windows XP. Problem seems to be that Device Manager sees it as an Unknown Device under the Universal Serial Bus controllers.
Unfortunately, Microtek doesn't support the V6UPL for any Windows OS beyond XP. The drivers are available here: http://support.microtek.com/downloads/bycategory.phtml?slct_tbl=1&slct_mdl=2 .
What version of Windows 7 are you running? Click Start > Control Panel > System and Security > System. If the version name ends with x64, you have the 64-bit version; otherwise you have the 32-bit version.
If you have the 32-bit version, try using the driver from the above site with the compatibility mode. Right click on the .exe file and choose Properties. Then select the compatibility tab. Set the program to always run in the compatibility mode for XP. Then right click again and choose Run as administrator. (You may need to disconnect the data cable and uninstall the Unknown device before trying to install the XP driver).
This will probably not work for Win7 x64. There are workarounds that you can use. You need to connect the scanner to a computer running an older version of Windows. This can be a physical second computer, a dual boot computer or a computer running a virtual version of the older OS. If you have Win7 Pro or Ultimate, or upgrade to one of those versions, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. Then install the XP scanner driver in the XP mode program as if that is the only computer running. The only issue is that you can't share files or your printer between the virtual and real computer at the same time. You will be prompted to uninstall the printer if you try to install it on both machines. You can put files on external media to share them. Other virtual computer programs are Parallels and VMWare. However, you need a licensed version of the older Windows OS to use any of the other alternatives.
I hope this helps.
Aug 18, 2011 | Microtek ScanMaker V6UPL Flatbed Scanner
I have a ce-100 futura sewing machine that will not work with windows 7 what do i need to do to fix this problem
The Futura software and the machine drivers exist for Windows 98, NT, 2000, ME, or XP. If you have Win7 32-bit, you may be able to run in the compatibility mode. Load the CD into the optical drive, then right click on the .exe file on the CD. Then choose Properties. Select the Compatibility tab and check Run this program in the compatibility mode. Click Apply and OK. Then right click again and choose Run as Administrator. This isn't guaranteed to work since the changes in the OS are significant.
To check if you have Win7 32-bit or the 64-bit version, click Start > Control Panel > System and Security > System. The title will say Windows 7 (Version) for a 32-bit OS. It will read Windows 7 (Version) x64 for the 64-bit version of the OS.
If you have the 64-bit OS or the compatibility mode doesn't work, you need a computer running an older version of Windows. This can be a second computer, a dual-boot computer (where you select your OS at startup) or a virtual computer (that runs inside the real computer). If you have Win7 Pro or Ultimate or upgrade to one of those versions, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
(The last person I dealt with with the issue of an embroidery machine not talking to Windows 7 kept their old Windows XP computer just to work with the sewing machine. Fortunately the old computer was still working enough to use for the purpose.)
Jun 28, 2011 | Singer CE-100 Futura Computerized Sewing...
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Jun 25, 2011 | Broderbund American Greeting CreataCard...
I have a UMAX Astra 4450 scanner, and I'm trying to use it with my new Windows 7 computer. I still have the installation disc, but when I installed (I tried from the UMAX site too) no drivers were...
Hi I had the same issue. I just downloaded the evaluation copy of Vuescan, which includes a Windows 7 driver that works with this Scanner (32-bit & 64-bit) When selecting the model of Scanner I chose "Umax Astra 5400", which worked fine with the 4450.
Hope that helps! Ian
Jun 06, 2011 | Umax Astra 4450 Flatbed Scanner
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
I purchased Hebrew Tutor and cannot install it on my Windows7, 64-bit computer. Please help.
Unfortunately, the Hebrew Tutor from QuickVerse was written for older Windows OS versions. It supports: Windows 95, 98, ME, 2000, XP Home, XP Pro, or NT 4.0. The changes in the Windows OS over time has made the installer totally different and the program isn't signed for a 64-bit OS. http://www.quickverse.com/shopfiles/product_details.asp?ID=41011 has the support details.
There are two possible ways to work around the issue. The first is to try to install the program (and then run it) in the compatibility mode. This may work but often doesn't. Right click on the installer (from the CD's directory) and choose Properties. Then go to the Compatibility tab and chose Run this program as compatible with XP. Save and close the properties box. Then right click again on the installer and choose Run as Administrator. If it installs, repeat the compatibility process on the program itself.
The solution most likely to work is to use a computer with the compatible OS versions. This could be a physical second computer, a dual-boot machine or a virtual computer. If you have Windows 7 Pro or Ultimate, you can run the virtual computer with XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. For other setups, you will need a licensed version of the older Windows OS. Virtualization packages include Virtual PC, Parallels and VMWare. Then install the Hebrew tutor as you normally would to an XP computer. (Note: virtual computers do not share hardware with the real computer. You can only install a printer to one machine at a time. You can share files by saving them to external media (optical RW disc or flash drive for example).)
I hope this helps.
Feb 21, 2011 | Computers & Internet
Cant'r run pyro5 on windows 7. is there a solution other than buying new pyro software?
Yes, but it may be more expensive then buying the new Cakewalk pyro Audio Creator 1.5 ($40). The cost will depend on your version of Windows 7 among other issues.
From the Cakewalk site: "pyro 5 and the other versions listed above will not launch properly under Windows 7. They will not function at all."
The work-around is to run the software such that it thinks you are using an older version of Windows. There are a two ways to do this with one computer: 1) run a dual boot system with Window 7 and an older version of windows, 2) run a virtual computer with an older version of Windows inside the Windows 7 system using Parallels, VMWare or Virtual PC.
In most cases for either option, you need a licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate, you can get the virtual computer with XP for free. Download Microsoft's Virtual PC and then the XP mode package. Install them in order and install your Cakewalk software to the XP computer as if that is the only computer. The only issues can come up is that peripherals (like printers) can't be installed on both the real and the virtual computer and sharing files has to be done by saving to optical or other external media.
I'm not sure how much of a learning curve would be involved but there is a free audio editor available. See http://audacity.sourceforge.net/ for more information - the Win7 version is still in beta but works.
I hope this helps.
(Virtual PC http://www.microsoft.com/downloads/en/details.aspx?FamilyID=04d26402-3199-48a3-afa2-2dc0b40a73b6; some updates are also available.)
Dec 30, 2010 | Cakewalk Pyro Audio Creator - Windows CD...
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
How do you uninstall windows xp pro to the previous version?
If the copy of Windows XP Pro you have installed is already registered/verified as having been previously installed, you have three options:
1. Call Microsoft and purchase a COA (Cert of Auth) for your copy. This will get you a new "key" and will allow your copy to verify.
2. Simply buy a copy. If it's unavailable in a local store, search Google with something like, "Buy Windows XP Pro" for places to buy (I like Amazon.com for things like this, because one is perhaps slightly more likely to buy a REAL copy. :-))
3. Ditch Windows entirely. Have a computer savvy friend go to http://www.ubuntu.com and download/burn a copy of Ubuntu 8.04. Pop it into your CD drive and install a fully-working operating system, web browser (Firefox) and Email Client (Evolution--the equivalent of a full version Outlook). A full office suite and multimedia apps are included. Free. If you do not have a tech-savvy friend to ask, go to the website and request to have an installation CD sent to you for FREE.
Jul 17, 2008 | E-Machines eMachines Desktop PC
HP Deskjet 3915 InkJet Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
