Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Can see music on memory card
I have a 2gig micro sd card and I successfully copied music to it through the card reader on my pc. After inserting it into the phone, I can't see anything under My Music. Can you tell me what I'm doing wrong?
A few suggestions (Not in any particular order)
Format the SD card in the PC, Make sure the songs are in MP3 format, (In XP use windows audio converter to change if needed), make sure the MP3 files have a bit rate of 128 kbps or less. Make sure the phone is set to 'data connection' not 'memory
card connection' because the phone cant see the files, connect the SD memory card to the PC, use 'my computer' to view folders, you should have an 'audio folder' if your MP3's are contained in folders try removing each MP3 file from its folder and place directly into audio folder (cut & paste) delete the empty folders, you can organise any playlist's on the phone. If possible download WMP11 & Moto multimedia Plug-in, (makes loading a bit easier). Chris
Posted on Jan 20, 2008
Mu computer is windows 7 professional
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Transfer Pictures From MicroSD Card to PC
How to use card reader
Card Readers Adapters
Memory Card Readers
Aug 20, 2016 | Cameras
How do i transfer files from my cobra digital mini 150 to a pc?
Yes purchase an USB micro SD card reader.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 09, 2012 | Cobra Digital Mini 150 5.0 Megapixel Mini...
I want to download a music to my microsd
insert you memory card to computer, use card reader
at computer open windows explorer
chose the music that you want to download to micro sd
then right click chose copy
go to micro sd drive then right click then chose paste
done
Feb 24, 2011 | SanDisk 4GB microSD High Capacity Memory...
How to download music
The best way is with an SD/Mini sd memory card. Your phone can accept a 2gig card max. Get a SD reader or a base reader, to USB adaptor, get the SD/mini SD card w/adapter and just copy files from your computer to the mini card and insert that into the phone. Most cells do not allow downloads in the same way as computers do. Yes you can download themes and ring tones but not files like MP3's. Here are pictures of the tools needed to put music on your phone. his is the mini SD with adpt. mcneb_3.jpg here is the reader, mcneb_4.jpgHope this Fixya up.Please leave a testimonial if it does. Thank you for using Fixya.
Dec 11, 2010 | Nokia Classic 2700 Cell Phone
How do i download music fRom my computer onto a SanDisk with a micro in my cell phone
hi what you will need to do is either use a USB cable from your pc to your cell phone, the memory stick (micro sd) will show as a removable device then just copy and past the mp3 files that you want to copy, the other way is to buy a sandisc micro card adapter, this looks just like a normal SD card, but at the top of it there is a slot that you put the micro SD card in then put it in a card reader as normal, then transfer the music over to that disc, when done just pull your micro sd card from the adapter and insert it into your cell phone as normal and away you go...hope this helps
Aug 18, 2010 | SanDisk Computers & Internet
I cant get my LG VX9200 to accept my WMP files
How are you loading them?
I have successfully used the Micro-SD card by removing it from the phone (Power the phone off first, please!), and inserting the micro-SD card into my PC card reader using an SD-Card adapater, which makes it appear as a Drive to my (WIndows) PC.
I then just copy music files into the "My Music" folder, and they show up when I put the card back into my phone.
I have also been successful using a USB cable, and then settting the phone to "Main Menu | Settings & Tools | Tools | USB Mass Storage" Then the phone looks like a disk on my computer, and again, I copy the files into the "My Music" folder on the micro-SD card while it's in the phone. Don't know if you can copy to internal phone memory in this method; I've never needed to try it.
A couple of things: I'm using ".m4a" files out of iTunes; I have also used ".mp3" files I've edited as ringtones, but I haven't tried ".wmp" files, so I don't know if it's a file format issue.
So are you successfully copying files to your phone and just not able to play them, or are you not able to even get them copied onto the phone?
Jan 28, 2010 | LG enV3 VX9200 Cell Phone
I have a sd micro card and i want to load music on it from my computer to put on my phone
This is a relatively easy problem.
You can do so by using a memory card reader.
You can easily get a memory card reader from any local store at a cheap price, depending on your country.
Most of the Memory card readers come in USB type, so what you just need to do is to plug it in any available usb port on your PC, and then insert your
sd micro card in the appropriate port for it.
For SD Micro Cards (The Smallest Types), most times you might need to first insert it in a Small Card Adapter that comes with SD Micro cards, before inserting it in your USB Card Reader.
Hope this helps you out.
Kindly let me know how it goes.
Good luck.
Nov 19, 2009 | SanDisk 1GB microSD Memory Card
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
110 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
