The buttons which supply the power levels will not stay down on my electric fan.
  • roboz17 Nov 18, 2009
    Yes it was,however I don't think I can access the buttons.Thank you.
    President:
  • 2,185 Answers
When you tried to press the power button and you did not hear a "click" sound, then there could be a broken part on the button itself. If you continuously press the button and hold them, try to see if the electric fan functions. If yes, then you need to bring this to a repair shop to have the button replaced.
Posted on Nov 18, 2009
Gateway 831gm - press power on, power is there but will not stay
If the power button is not defective in/out, it means yuo have a defective power supply.
Thanks
Jul 30, 2010 | Gateway Computers & Internet
P4 PC with Antec power supply won't start when cold
I haven't heard of a sensor that keeps it from starting when too cold. Usually in electronics, if it is a cold problem, there is a cold solder joint somewhere. When you apply heat, the joint solder expands enough to make contact and once electricity is flowing, the joint stays heated due to the resistance provided by the cold joint. Since the heat is applied to the power supply, I would say that the power supply is the problem again. If the power supply is still under warranty, I would exchange it or get my money back and go with a different name brand since you've experienced power supply problems with another model.
Dec 19, 2009 | Computers & Internet
The buttons which supply the different power levels will not stay down
Your members supplied the answer which is to replace the whole button part, however, the buttons cannot be accessed.
Nov 18, 2009 | Dryers
My computer wont turn on
Remove the power cable and hold down the power button for about 30 to 60 seconds. plug the power back in and see what happens. If fail look at the back of your computer ans make sure that the fan for the power supply is on. Also make sure that the red switch is set to 115V and not 220V. This is also located in the power supply.
If al has failed your power supply is no longer working and will need to be replaced.
Apr 22, 2009 | E-Machines eMachines Desktop PC
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
