Question about Maytag MSD2456G Side by Side Refrigerator
How do you reset the change filter light on the door?
    Problem Solver:
  • 5 Answers
On newer Maytag fridges Press Options, then Water Filter, then Reset, and then Yes.
Posted on Nov 20, 2009
It is a GE microwave that says reset filter
Open the microwave door and press the access panel above the cavity opening where it says "PUSH" to lower the panel door. Models with an Upfront Filter have a Reset Filter notification light on the control panel to indicate when it is time to change the filter. The Reset Filter reminder will light every 6 months.
Sep 16, 2017 | GE Microwave Ovens
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
Filter light on
Water Filter Status Light and Filter Reset
The filter reset control allows you to restart the water filter status
tracking feature each time you replace the water filter. See "Water
Filtration System."
After changing the water filter, reset the status light. Press the
OPTIONS button to enter Options mode, then press LOCK to
initiate the reset, then press MEASURED FILL to confirm that
you want to reset the status light. When the system is reset,
the "Order" and "Replace" icons will disappear from the
display screen.
These instructions can be found in the=> GZ25FSRXYY2 User Manual . As for the dispenser and ice dispenser problem this could be related to a loose connection in the door where wiring attaches to control panel and/or where door wires go from door to cabinet also a defective pressure switch where glass is pressed to get water or ice. Can you tell me when this additional problem began?
I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | Whirlpool Refrigerators
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
Change filter in door has the light on after the filter was changed. How do I reset the light.
On the dispenser panel you should have a light pad and a lock pad If you hold both the light and lock pad in for about 3 seconds the light will reset.
Sep 01, 2011 | Maytag Refrigerators
Filter light amber on the front panel
this means it's getting time to change the water filter,,if u have already change the filter u can reset this by opening the refrigerator door and push and hold the light button for 10 seconds this will reset the filter light
Apr 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Filter light won't go off
Did you press and hold the reset filter light for at least 3 seconds?
Jul 11, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Maytag MSD2456G Side by Side Refrigerator Logo
160 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
