Question about Boating
How to tie a parafoil kite lines . Do you tie each of the minor lines to the centre pivot ring of each of the two major control lines when a) the kite is dead flat before it commences to catch air or, b) when the kite is curved to approximate the shape it will take in full flight How far from centre of the plan view of the flat kite does the ring occur in both directions on the plan view and away from the kite How are the upper strings measured so they are longer than the lower strings by the correct amount to set the angle of the kite to the projectied line of the control line.
  • 32 Answers
SOURCE: What are the torque specs for 1990 dodge dakota front suspension.
call carquest or other parts house and ask them for the torque specs or a front end alignment shop.
Posted on Sep 28, 2008
SOURCE: fine line down centre of screen
call Toshiba ASAP if you still have warranty, the TV needs to be replaced. The line will get worse!!
Posted on Mar 18, 2009
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
  • 122 Answers
SOURCE: Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Posted on Jul 16, 2010
  • 122 Answers
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Posted on Jul 18, 2010
I got a 1989 big bear it pulls to the right i put new tie rid ends and upper and lower balk joints in pulled cv axel it seems to be ok steering bearings seem fine also anyine have any ideas
Try aiming the handle bar straight and pull some kite string across the rear wheel , lightly touching the sidewalls of the tire. With the length of the string pulled across the front tire, adjust the outer tie rod so as to make front tire lightly touch the string. That should square the front tire to the back tire. Once the front and rear are squared, adjust tie rod in 1 turn for a slight negative toe. Do both sides while making sure to keep the handle bar straight during string and adjustment. That should help.
May 25, 2017 | Cars & Trucks
How was ancient Chinese kite created
Here is your answer...enjoy.
Kites were invented in the early Warring States Period (475 - 221 B.C.) by Mozi and Lu Ban, two philosophers who came after the teachings of Confucius. ... Kites played a role in providing military intelligence for the Chinese forces.
The History and Culture of Chinese Kites - China Highlights
Apr 17, 2017 | Computers & Internet
How do you assemble a
Be sure it is bolted together properly. Anything you tie to your roof should be very durable and well-built or it may find a new life as a KITE!
Jul 10, 2014 | Thule Sportrack A21002s Frontier Roof Rack
Serpintine belt
You can use kite string or twine, route the string around the pullies and tie off, cut and remove and measure with tape measure
Jan 01, 2014 | 1991 Ford F150
Where can I buy some inexpensive kite surfing gear?
Here are a few places:
Jan 14, 2013 | Water Sport
Two front wheels misaligned, one is straight and the other points outward
To give you a professional soultion I really need a complete model number.
Here is what happens when steering becomes a problem on ANY brand of riding mower.
1. Tie rods get bent
2. Wheel spindle pivots get bent on one side.
3. Pivot bearings or bushings get worn
4. Linkages from the steering wheel to the tie rod pivot connection get bent.
On the basic bottom of the line Craftsman riding mowers the tie rods are fixed and not adjustable. However if you look for a mirror image left to right of the tie rods often you will note that one of them is bent in or out... or is shorter than the other one. There are after market tie rods that are adjustable. This is over 40 years of experience talking here.
THe best way to do an inspection of steering is to place the mower on tripods so that the fram is being supported and not the steering components and then set the steering wheel to the straight position and inpsect ALL of the steering and suspension components for the front end.
Without your model number this is quite generic. With a model number I can show you a parts diagram by item number of what to check.
Thanks for choosing FixYa,
Aug 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i remove the rotor after removing calipar
remove centre cap bolts, remove then circlip in centre, remove that section, then look for 3 philips head screws in "holey" lock ring and remove screws(sometimes need to do with impact driver), remove lock ring after undoing screws, then undo silver ring (anti-clockwise) by putting philips screw driver in holes of silver ring with lines in it and turning, then remove disc and hub as assembly (hub does separate if you undo the 17mm bolts that hold the disc to the hub, must do up this ring firm then back off and then do up the old feel method way. align a line in silver ring with top notch of centre threaded shaft that ring goes on, to one of the sides then when you put "holey" ring back on you can get the lock screws into silver ring.
Aug 04, 2010 | 1999 Isuzu Trooper
Stunt Kite keeps crashing
Unless there is a problem with the kite itself. Look for broken or bent connection bars. If there seems to be nothing wrong make sure you are somewhere with lots of wind. like the beach 10-15mph winds at least. Make sure the string is let out in equal lenghts (Most likely your problem) and just let it fly for a few minuts before attempting any tricks. If you can get it up and there is plenty of wind but it keeps crashing then add a tail to give the "bottom" of the kite some extra weight. Good Luck.
Sep 01, 2009 | Toys
Wii wont turn on
Reset your power adapter.......unplug it from the wall and wii console. Let it sit for about 2 or 3 min to reset. Now plug it back into the wii console and see if that does the trick.....Mine worked after that. If yours doesn't I would just call Nintendo.
Jul 12, 2008 | Nintendo Wii Console
Boating Logo
281 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
