Question about GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacesaver Microwave is "Trippin!!"
We've had it for less than a year. It works intermittently. When it decides to fail, the display shows some funky looking symbols, the light & turntable work but it fails to heat-up. The cord is unaccessable so I go throw the breaker and that works sometimes-HELP!!
I had a similar problem and found that unplugging (or in your case leave the breaker off) for at least 12 hours then plugging it back in solved the problem.
Posted on Jan 10, 2008
Works but does not heat up
It may be damaged from inside. Check it to the Oven Specialist. He will assist you and told you that what's wrong.
Maybe its Power Problems that causing heat not to produce.
Feb 03, 2016 | GE SpaceMaker Microwave Ovens
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Heat won't work on ge spacesaver microwave oven --what to do from
heatman101
ioi
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver microwave ...it is 5 years old and stopped heating
I have an over the oven microwave that blew a magnetron after 4 years. Could be the same thing. It was out of warranty for the free labor, so I took it apart (I'm kind of a geek) and found out the magnetron was gone. Shortening the story: I bought a new magnetron from an online place and replaced it and it works fine. If you have someone replace your magnetron, see if you can get it for free-they have a long warranty on the magnetron ($150 part) and at 5 years, you probably qualify. Rich
Mar 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave not running
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk It's most likely a bad high-voltage transformer or magnetron, but it's hard to say without being able to check it. If it will run without blowing the fuse, you may be able to do a test. This should only be performed by someone observing safety warnings mentioned at the link above. Put about 2 cups in a microwave-safe container inside the cavity. Run the oven for about 3 minutes, or until it blows the fuse. Then unplug the oven from the wall, and carefully feel the top of the high-voltage transformer and inside or near the finned area of the magnetron to see if either gets really hot. If one does, it's the likeliest suspect. When the high-voltage transformer fails, it often gets discolored and smokes, but not always. You can look for that, too. It's very important that the internal cooling fan is running, and that the air vents are not blocked opr plugged.
Aug 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
112 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
