Question about Whirlpool ET8CHEXSQ Dryer
Whirlpool TED5780JQ0 i have a whirlpool electric dryer i have a problem where the clothes are not drying. i poped open the back turned on the dryer and noticed that the heating element turns on for a brief second then turns off never to turn on again until i turn it off then back on again. i checked four heat sensors they all have continuity on all of them and they all have closure so i just need some ideas. thank you
  • Whirlpool Master
  • 3,051 Answers
Hello there:
here are some helpfull ideas for you
  1. Examine the coils. If your dryer isn't producing any heat
  2. the terminal bracket that secures it may need to be replaced. Also check to see if the thermal fuse is blown, if both volt circuits are on and the thermostats are functional.
  3. Step Check the vent. If a load takes longer than one hour to dry clear the vent duct of any obstructions. Determine if the heating element is partially burned out .
  4. would get a new element anyway ok?
  5. I hope that this is very helpful for you
  6. best regards michael
Posted on Nov 18, 2009
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
There is a loud squealing sound when I turn the dryer on. Whirlpool model GEW9250
Your dryer belt is loose, you may just have to open the dryer and reset the band, but most likely you will need to order a replacement set from whirlpool.
May 26, 2012 | Whirlpool GEW9250 Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
Have a whirlpool electric dryer. My wife said that she noticed a burning smell from the back of the dryer while it is running. The clothes are still being dried though. Any suggestions? We have had this...
Usually, lint has found it's way into the burner chamber. This is often evidenced by small brown spots on clothes. To resolve, unplug the machine and open it up and investigate the burner area.
When finished cleaning, remove the outlet hose, turn on the unit and form an opinion about air flow.....Hook hose back up, turn machine on, and go outside the building, and verify very similar air flow volume. Any restriction will slow drying and allow more lint to get drawn into the air inlet.....
Mar 21, 2011 | Whirlpool WED6400S Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool condensed tumbler dryer
check ur dryer vent in the back u might have pushed it back too far and kinked the hose ar u might have a buildup of lint in the dryer vent pull the dryer out and take the dryer vent off and run a load of clothes like this if it works look for a lint buildup in the hose or u just had the hose kinked
Feb 26, 2010 | Whirlpool LER5636P Electric Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Whirlpool dryer doesnt dry clothes
If the dryer heats , dry a load without the duct on . If it dryes fine , then problem still with vent somewhere .
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Feb 11, 2009 | Whirlpool LEQ8611L Electric Dryer
Whirlpool ET8CHEXSQ Dryer Logo
194 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
