Question about Jensen SC-340A Remote Control
Toshiba Remote CT-877 problem
My Toshiba Remote CT-877 will not turn the TV on & off. For a while it would change channels, but now it won't. Now, all it will do is adjust the volume. I have seen 2 other posts on this problem, but no solutions. I tried the reprogramming, but it didn't help. I work in a school that has cable access for the whole school. The TV works fine and no one else is having problems with remotes in the school. Please advise.
lindaservice@yahoo.com
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Posted on Mar 20, 2008
I was having the same problem with my CT-877. I could adjust the volume, but not much else.
I think I accidentally just fixed it (knock on wood). There is a button labeled "TV" to the left of the channel up-down button. I pointed the remote at the tv while the tv was turned on, pressed that button and held it a little bit, then tried the power on/off button and it worked!
I hope that that works for you.
Posted on Feb 02, 2008
  • joaz50 Jun 26, 2011
    I had the same problem -- tried this suggestion-- and it worked immediately. Thank you.
  • I_like_crt Jun 26, 2011
    Thanks for the comment! I was having the same problem again this week and completely forgot that I had posted a solution three years ago. So, thanks to your reminder, which came as kind of a weird coincidence, I was able to go back and read and follow my own advice! It worked again.
The manual of my Toshiba TV says that you can reset it by pressing the "ON" pushbutton for five seconds and then the "TV" button. Do this two or three times and it resets. I think it's a pain in the ... but (no pun intended) what are you going to do? I tried to contact Toshiba but no answers yet to this nuisance. Good Luck
Posted on Jan 17, 2009
  • Jeffrey Maddox
    Jeffrey Maddox Sep 09, 2015
    This solution works! Just used it on my remote. Glad that someone kept the manual!
I tried to program the TV 125 channels but only channel 3 is viewable
If it's a universal remote, you should find another one.
If original, it's not working
Jun 02, 2015 | Toshiba Televison & Video
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
I have a toshiba ct-877 theaterview sd tv and I can't make my xbox work, I don't even know if I am on the right channel. I am just a Mom and my poor kid, days after christmas, still no working xbox...
I believe ct-877 is the toshiba remote model number, look on the receipt, or the back of the TV for the TV model number, then we can get you the right answer :-)
Jan 03, 2011 | Video Game Consoles & Games
I cant figure out which button is for the code search on this remote
It should be channel up button. Just keep pressing it, allowing 3 seconds in between presses. Once your television turns off, you have found the code. Then press enter, and try turning your television back on. (Note: not all televisions will power down. Some may only change the channel)
Nov 04, 2009 | Toshiba CT-877 Remote Control
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Jan 06, 2009 | Toshiba CT-90157 Remote Control
Toshiba Remote #CT-847
where can I get the manual for a Toshiba ct-847 remote
Dec 06, 2008 | Toshiba Televison & Video
Need Help Using Toshiba Remote
here is a link to the user's manual for your remote:
http://www.remotes.com/remotes/documents/Toshiba/CT-877.pdf
hope that helps
Jan 15, 2008 | Televison & Video
30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
Oct 29, 2007 | Toshiba 30HF85 30" TV
Jensen SC-340A Remote Control Logo
2,819 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
