Question about Toshiba Satellite A200-0ET00X Notebook
It will not turn. it acknolwledges that it is plugged in to power but will not start up
    Guru:
  • 1,738 Answers
Hard drive is bad.
Posted on Nov 18, 2009
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
Had 04 transit connect for 6 weeks. always started fine till week ago when turned cold. glow plug light only shows for about 1 second, replaced glow plugs but still the same. can only start every morning...
Sounds like the timer is bad. Since you have power when warm, the power relay must be giving the timer juice. The way it is suppose to work is you wait until the glow plug light goes out and then try to start. In cold weather it should take longer for the glow plug light to go out.
Nov 03, 2013 | Ford Transit Connect Cars & Trucks
When I turn on my acer aspire 6920 laptop it will not start up. I have the power lead plugged in but it won't turn on.
you mite have a conflict in the start up program. go into start up settings and see if theres a problem . if not try the acer recovery that should sort it out.
Jan 27, 2013 | Computers & Internet
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
I try to turn on my laptop, and it won't turn on. When it originally happened I was on it, without the charger plugged in, online. It was working fine, and then all of a sudden it shut off, and will no...
Your battery is probably completely discharged. This can prevent the laptop from starting even WITH the power plugged in. You might try removing the battery, then plug in the AC power adapter. Push the power button and HOLD IT down for 30 seconds (your laptop may or may not start up. If it starts, then shut it down normally.)
Replace the battery. With the AC still plugged in, repeat the start proceedure above. Leave the laptop on until the battery is fully charged. If this doesn't work, then your battery may be bad (this can happen all at once) or worse, your charging system isn't working (less likely.) Your power adapter could also be bad - is the green light on when it's plugged in?
You may have to repeat the proceedure a few times before it works as the battery needs to show a little charge before it will start.
Once started, press F2 while on the dell logo to go to the setup screen. Select the power options. and you should see if the battery is detected. If battery is detected, it should say "charging".
If none of this works, call Dell technical support 800 822-8965 for further assistance
Nov 29, 2010 | Dell Inspiron M5030 Laptop
7.3 Liter Diesel starts hard in morning, ok if not left more than 8 hours. How to check the Glow Plugs?
Your glow plug relay is located on the top of the engine on the right side toward the front. Some models there are 2 solenoids. A large one toward the front and a smaller one right behind it. The glow plug relay is the smaller one toward the rear. The larger front one is the intkae heater relay. To test the glow plug relay turn engine to on. dont start it. both of the large terminals should have power with key on. then turn engine off. only one large terminal should have power. If when you turn engine to on you only have power on one side then go to this test. Turn engine on and test smaller wire. it should have power. If it does replace the relay. If the smaller wire does not have power you have an ignition problem or power (wiring) problem to the relay. Also note the engine needs to be cold. If temp of engine is over 130 the computer will not turn the glow plug circut on! Most of th time this is what fails and not your glow plugs.
Oct 27, 2010 | 1996 Ford F350 Crew Cab
Sir, i have bought a acer laptop model aspire 5920 but when i was working on it suddenly it shut down and till now i cannot made it power on can you tell me the problem
Remove the battery and the power adapter, wait 5 minutes, plug in the power adapter and try turning it on, if it doesn't turn on, remove the power adapter, plug in the battery and try starting up again, if it still doesn't work plug in the power adapter, try starting up.
Is the power adapter working? does it have a green led on it that shows that its powered?
Sep 10, 2009 | Acer Aspire 5920 Notebook PC
Starting problems
when you say, "just drains the power", do you mean it kills the battery trying to start? when its turning over and over and not starting, did you take the plugs out and see if they are wet with fuel?
Jun 03, 2009 | 1982 Suzuki GSX 400 FS impulse
2005 chevy 1500 4x4 differintail noise
You may want to check your transfer case for a leak on the passenger side, 5th. bolt up from the bottom, the fluid will be blue in color, this is known as PUMP RUB in which Chevrolet refuses to acknolwledge.
Brad
Nov 17, 2008 | 2003 Chevrolet Silverado 1500
Toshiba Satellite A200-0ET00X Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
