My cd/dvd driver didnot show on com..i have try uninstalling my driver and update driver too...but till now having problem..so plz help me at vimal_vcheart@yahoo.com
  • 4 Answers
U may be having a filter issue::
click on start>>type in "regedit" in run command>>the window that comes up is the registry files window>>now follow the instructions below :: STRICTLY ::
HKEY_LOCAL_MACHINE>>SYSTEM>>CONTROL>>Current Control Set>>Control>>Class>>check for the no.::967 in the list of drivers listed(the no. will be in between letters)>DELETE THE "UPPER FILTERS" AND THE "LOWER FILTERS"....
Posted on Nov 18, 2009
    Guru:
  • 1,738 Answers
I am sorry to report bad Dvd drive
My dvd rw ad 7560s is'nt reading any Dvds as it used to. Whenever i insert a disk,it shows no disk inserted.i have to install an antivirus and softwares...plz tell me wht to do????
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a disc the drivers could be on it
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
My sony crx320ee cd-rw/dvd stop functioning normaly, cannot burn cd now. plz hlp!
i would recommend uninstalling the drivers completely and reinstalling them, however most drivers for cd roms cd/rw are preinstalled, and the only thing you can update is the firmware for the device itself. you may want to try unhooking the drive and rebooting the computer, then turning off the machine again, and reattach the drive, and restart. that might force it to re-configure and re-load the drivers
Dec 29, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
When i put cds in it works when i put a dvd in i go to computer the drive shows nothing but when i put a blank dvd in it shows it but cant burn nothing to it
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
Dec 27, 2010 | Lite On LH-18A1P DVD RW Dual Layer Burner
I CANNOT FINISH DOWNLOADING MY NEW PRINTER BECAUSE IT STALLS--IT SHOWS TOO MANY MINUTES LEFT BEFORE INSTALLATION IS FINISHED.
hope this helps
Dec 18, 2010 | Computers & Internet
Will not open?
Get a paper clip or something thin that will fit in the hole on the front panel of your burner.
push the paper clip in the hole and push till the tray opens.
Hope that helps
Dec 17, 2010 | Compaq (200356-001)...
My pioneer DVD-RW DVR-107D (Driver) will let me play a CD or DVD. When I want to write files to it the Wizard tells me that the Blank disk is full when it is not. I tried replacing It with a new one but...
hope this helps
Dec 13, 2010 | Pioneer DVR-107D DVD±RW Burner
My dvd ram cannot read any components on disc. It shows 0 bytes / blank disc.
make sure that the dvd-rom is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
Dec 07, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I changed my motherboard to gigabyte. now m not able to write any cd or dvd. it shows a driver problem and get's aborted in the middle of burning
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 17, 2010 | HP Computers & Internet
CDROM drive not recognized
Does the CDROM/DVD drive appear in the device manager? If so, try to read several different discs. The lens could use cleaning. Use a cleaner disc or a q-tip with a little bit of windex on it. If this doesn't fix the problem, simply change the DVD-drive
Nov 04, 2009 | HP Pavilion dv6000z Notebook
My laptop is not showing me the DVD/RW.
Go to device manager by typing devmgmt.msc in RUN option which u find in START option... after that click on CD/DVD drive and press Uninstall.... after that restart the notebook will install CD/DVD drive drivers...... hope this could help u.
Jul 23, 2009 | Quantum Meridian CD Net CD-ROM Drive
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
