Question about Electronics - Others
I have a true life 4500 portable generator not enough voltage
I have a true life 4500 portable generator and its not putting out enough voltage to power anything where does the voltage come from dont have diagram and not sure if it has a regulator in line somewhere that could be bad
Where could i find a mot capacitor for the 4500 series and what do they cost
Posted on Jul 13, 2014
4 Suggested Answers
  • 250 Answers
SOURCE: Have a True Life 6000e
Make sure the square capacitor is not burned out or melted. Some of them had the capacitor under the rear end of the generator that has 2 screws holding it on. The other place where they put the capacitor is under the plastic cover on the main pannel. You have to take out 4 bolts and snap the plastic cover in the back of the pannel off. You would see if the cap is bad it would be melted and out of shape. You can use a electric mot capacitor 25 microfarid at 350 volts.I used to work on those generators quite a bit.
Posted on Mar 18, 2011
blueextc3221
  • 15935 Answers
SOURCE: Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
Posted on Dec 22, 2008
  • 20 Answers
SOURCE: In need of Stabilizing voltage of power generator
Solved problem upon installing a ready made stabilizer. Thanks for the opportunity to publish my inquiry. Chawah.
Posted on Dec 31, 2008
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Have a 1200e true life gen.only putting out half the voltage.
    I've repaired a few modern generators and have not seen a diode go bad yet, its usually a capacitor or wires rubbed through (broken off from vibration)...also if there is two circuit boards, either one could be bad or just a wire to them
    Sep 24, 2014 | Cars & Trucks
    We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
    How long have you had this generator?
    Has the generator worked on all of these loads before?
    Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
    Your AC is an inductive load.
    Your lights are resistive loads
    An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
    I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
    Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
    Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
    Since the older cars had generators removing the belt had no affect with the motor running until the Battery went dead,also the car would run without a battery because of the permenant magnets in the...
    Hi, I am old enough to have worked on both systems. Now, when you remove a belt from the newer or older systems, the engine will run as long as there is enough voltage in the battery. No difference here. The generator dies not have a permanent magnet but residual magnetism in the rotating armature. It would build up voltage and would have to have the regulator control the output. The residual magnetism is a small amount and is similar to the residual magnetism that is currently used in all portable generators or to be correct portable alternators used for your 120 / 240 volt electricity. The car alternator does use a rotating field that relies on an electrical current supplied by the battery through a regulator. The vehicle will still run if the alternator is disconnected, until the battery runs low or an electrical load of sufficient current draw will cause the ignition system to drop out, thus the engine stalls. Remember the same was true of the generator systems as well. I have driven automobiles where the alternator failed and the engine shut down a few hours later. There is no difference with removing the belt or having the alternator or generator fail with the belt on, there is no output to charge the battery and keep the voltage up to run the vehicle. A generator is a device which makes electricity in a DC format. An alternator is a device which makes electricity in an AC format which can be used as AC or converted to DC. Either can have permanent magnets in the rotor. But we use regulators in most cases because with plain magnets, we cannot accurately control the output.
    Mar 06, 2011 | General Tools ETK100 Utility Kit...
    With my generator running i have ac power but my ac does not come on
    Make sure your generator is rated high enough to run you a/c. Also is you a/c 120v or 240v? Do you have it plugged into the right voltage?
    May 08, 2010 | Yamaha 4500 Watt Electric Start Generator...
    Have a onan 4500 watt generator on a bucket truck. i have no output at recepticles, can you help.
    Onan units have a breaker switch on them that has to be in the right position or you get no power. Can't tell you for sure where it is on the 4500 but on the 4000 RV series it is tucked in behind the on board start switch
    Mar 03, 2010 | Watts Onan Portable Generator - 4000 ,...
    RV Onan 4000 runs fine but not putting out enough voltage to run anything
    Not sure how to set it up but you can take it and have the voltage turned up on your generator or the voltage regulator is out.
    Sep 09, 2009 | Watts Onan Portable Generator - 4000 ,...
    No output from my generator
    check breaker, your outlets should be like a gfi
    May 21, 2009 | Coleman Powermate Premium Plus 6250W...
    Honda EMS 4500 Generator - High Voltage Problem
    As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
    To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
    Mar 31, 2009 | Coleman Powermate Premium Plus 6250W...
    Electronics - Others Logo
    640 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
