Question about Makita 10" Miter Saw LS1030N
Makita LS1030 miter saw, base doesn't rotate as freely as it should
  • mchlmckee May 11, 2010
    Removed the fence and blade kerf guides to access retaining bolt in center of turntable. Removed turntable and motor assembly. Cleaned all surfaces of old grease and relubed, reassembled and it now moves freely as it did when new.
  • 44 Answers
Dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
Posted on Nov 18, 2009
  • Walt B Jan 13, 2015
    My older Makita LS1030 (not LS 1030N) does not have a retaining nut on the bottom, like the 1030N. It is different than the "1030N" in the parts diagram. I cannot get the turn base/plate separated from the base. I've squirted penetrating oil, without success to date. Any suggestions?
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
Makita LS1030 (not LS1030N) won't turn.
Turn it over ,
there is a 1/2 moon type metal ring called a "slide plate" that is holding it to the base. It is part #94.
Here is a link to a pdf
http://www.toolpartspro.com/image/LS1030/LS1030-Makita-PB.pdf
Hope that helps & good luck.
Don
Jan 13, 2015 | Makita 10" Miter Saw LS1030N
How do I replace the compression spring on a Makita LS1030 saw? I have the older version with the straight handle, not the "D" handle.
Dear Leonard,
I see that the Makita LS1030 does have a different compression spring mount than the newer "D" handle models. There is a parts schematic of your saw with the straight handle at http://www.ereplacementparts.com/makita-ls1030-miter-saw-parts-c-97_98_99_322.html. Perhaps this will aid you in puzzling out the disassembly and repair of your compression spring. So you know, it appears that the primary compression spring for your exact model is now considered obsolete and is unavailable on most parts replacement websites.
If if your problem is just that the spring is weak, a local machine shop may be able to tell you if the spring can be re-stretched to return it to its new compression level.
Makita is known for their excellent customer service, and if you call the parts/repair division of the company (Contact info located on Makita website) the technicians may be able to not only coach you through the spring replacement process. You should also ask if the spring on a newer LS1030 series is interchangeable or if Makita themselves have any NOS springs for your saw in stock.
Good luck in your search,
E Bishop,
Sep 29, 2014 | Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
LS1030 miter saw. blade brake not working all the time.
Could be dirty or worn brushes not making contact properly, if not it is the switch which needs to be replaced.
Sep 05, 2011 | Makita 10" Miter Saw LS1030N
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
Does anyone know where I can download, for free, a user manual on a 10" Makita LS1030 Miter Saw? My neighbor gave it to me, but didn't have a manual.
Yes, go to "makitausa.com" and in their search on the right upper side of the site type in your model number and it will redirect you to a page so you can download the manual and also a parts breakdown if you need one. Let me know if you need more assistance and if I have helped you would you please vote accordingly. Thank you
Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Sep 20, 2009 | Makita 10" Miter Saw LS1030N
Makita 10" Miter Saw LS1030N Logo
675 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
