I need a picture tube for my mitsubishi vs-5051 40in projection tv, how much do they generally cost? whats a good website or store in my area of manor texas?
    Sergeant:
  • 295 Answers
Honestly, sorry to give you the bad news and I'm one for trying to repair then throw out but, buy a new 42" flat panel it will be a lot cheaper. Mitsubishi quite making these size CRT's over 5 years ago and a replacement tube would cost more than buying a new replacement 42" TV.
My thoughts is that this 5051 is over 13 years old.
Blessings,
A/V Media Tech Guy
Posted on Nov 23, 2009
Replacement bulb for mitsubishi VS-60705 rear projection tv
The set does not use a bulb, it is a CRT type set which means it has instead 3 picture tubes, a red,green, and blue.
In order to try to help what is this set doing and not doing?
Dec 18, 2012 | Mitsubishi VS-60707 60" Rear Projection...
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Mitsubishi vs-5051
First you can safely take off back and look for Screen controls&Focus, Gently turn up the 3 screen controls this will add light to picture, but you need to evenly turn up, the 3 colors are red, blue, green. the other 3 knobs are for focus. Do not turn them if you do you will need to realign the focus also. And if this doesn't help then there is a high voltage capacitor leaky in the flyback area.
Sep 14, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
What is the life of a big screen tv?
Sounds like the veritical circuit has a bad capacitor. The cost is dependent on the servicers in your area. It can also be dependent on whether you take it to the shop or have a servicer come to your home. Look on a Mitsubishi website to find a servicer in your area.
Feb 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
65 inch Mitsubishi tv Model # vs-60703
so does it have sound??? If so then the set is probably in a hv shutdown because of a weak tube or is in vieo safty mode as the vert has failed in the set. On cost here in Michigan a tube could cost up to 300 bucks + labor and on the vert repair about 250.00 to 400.00 to fix
Mar 30, 2006 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Electro Med Services...
