Question about Dual XNBP12D Car Subwoofer
Best Amp? i am thinking about buying these subs from my friend and am wondering what the best amp would be for them so i don't blow them out?
  • 106 Answers
You need a 2 channel amp with atleast a 1000 watts
Posted on Nov 18, 2009
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
I have just bought a soundstream pca1000d amp from.my friend but he did not have the remote bass nob so I was wondering where I could get it from
the bas control nob is just a grimack end a waste of money,You don,t need it because all the decks in the last 8 years have,Sub level control on them, Where you can adjust the level of bas from the (Deck) All your asking for to happen, Buy all so useing the bas control for the amp, Is to (Blow) Your (Subs) End fry your amp, When you use both of them for controling the bass, You are causeing the sub end the amp to over heat, I installed car audio for over 40 years , before i retired this summer, End seen lots of amps end subs that were damage, Buy guys haveing them hookup all so,End anouther thing that damage subs end amps, When they have the grain control on the amp crank right up.
Nov 07, 2012 | Car Audio & Video
What would be the best settings on a pyramid arctic 1000 watt amp for one JL audio w1 12
Your sub is a 4ohm woofer, running it in bridged mode + on right connection - on left connect as market on sub will give the best output. Your sub is rated at 75w to 300w and in this configuration will be getting just over 100w which about all the amp can provide with your sub/amp combo.
I don't know where they get the 1000w rating from either? the maximum the amp can possibly provide is 150w if running a 2ohm woofer in bridged mode.
Mar 08, 2012 | Car Audio & Video
JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
Most power out of amp w/out blowing subs
you may only be able to get but so much out of the subs. If you turn the bass down a little so the that you dont drive the subs so hard you may get a little more wattage out of them
Apr 06, 2009 | MTX Thunder 1501D Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
USING 1 CHANNEL
I can't find any documentation for your amp; it was made when Jensen was owned by Recoton, and they're no longer in business. With any 4-channel amp, you can't bridge all four channels into a single channel. What you can do, if you're connecting it to a single sub, is to bridge two of the channels into one channel and leave the other two channels unused. It doesn't usually matter which two channels you pick, but some 4-channel amps designate channels 3 and 4 (or rear channels) for the subwoofer. Whichever ones you use should have a "LPF" or "LP" crossover setting available.
Jun 30, 2007 | Jensen A600HLX Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Dual XNBP12D Car Subwoofer Logo
139 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
