Question about Mitsubishi WS-65809 65" Rear Projection Television
Everyone is green and advanced settings doesn't help
  • syeman654 Nov 18, 2009
    going to open it back up this morning should have mentioned i lost power with rapid flashing green power light so i replaced the 4 capc on main board which brought it back to life but mus have banged into something but i am shuor rbg were working but will double check and try to adjust (auto advanced can not compinsate for my screw up)
    color adj did the trick thank you so much!
  • Mitsubishi Master
  • 5,138 Answers
You will need to remove the back then with TV on look to see if your Red and Blue Tube are coming on with the Green Tube you also have a Focus and screen control Box it will have 3controls on Top for focus and 3 controls below for Screen drive for each Tube R/G/B try adjusting the screen drives to Red and Blue up and Green down you can also remove front bottom panel then remove the front screen it has screws that hold it on ,it slides up then off with yhis removed then you can see down into Tubes OK Mitsubishi is well know to have alot of poor solder connections on Power supply Board if you can solder resolder the Board that has your FBT flyback Transfomer on its a Big Part that will have 2 wires coming out of it -one will go to your focus and screen control box, It maybe the reason you only have green is because the Red and Blue need to either be turned up or they are not lighting up. Let me Know what you find then I will be able to tell you more about what esle you may need to do .
Posted on Nov 18, 2009
  • ladywinn
    ladywinn Nov 18, 2009
    Call Mats Electronics tell them to send you a catalog they will! they also have a In circuit capacitor Tester which comes in need alot of the times. 49.95 Mul-3333 1-800-628-1118 How to set correct color Go to menu turn color off then adjust R/G/B screen dive controls, get as close to a black and white picture as you can then turn color back on !
BMW e46 won't start because of the alarm.
Hi, if the car stay for long time the computer box lost memory. Now is not reading the key. You need to program your key again by BMW manufacturer. Also on bmw the alarm is connected to computer box too.
Jul 20, 2013 | Cars & Trucks
Kp57hw40 is a greenish color
If green appears to bleed out of objects then it's probably the saturation level is to high. If that doesn't work you can try changing the Hue setting more towards red and away from green.
If neither works and you don't have a warranty I would call your a local TV repair company.
Oct 22, 2012 | Sony KP-57HW40 57" Rear Projection...
I have an 11 blinker on my sony kp-51ws520 can you help me
11 if the blinks start when set is turned on is normal as set checks akb etc before turning crts on.
what was issue before? BRIGHT RED, GREEN OR BLUE SCREEN?
May 14, 2012 | Sony KP-51WS520 51" Rear Projection...
Please help me. I'm seeing a red and a green line on my sony vaio laptop screen. The red line was appearing from last one month. And the green one is appearing from yesterday. I want to remove those...
hi,
If this line is contineous then it would be a screen damage to your pc but if line doesn't appear all the time or screen flickers on a particular area of lcd or completely, it might be data cabel issue with it.
.....may
Jun 24, 2011 | Computers & Internet
Toshiba TP43h60 - Wondering what the dials are for
You are describing the MASTER SCREEN/ FOCUS CONTROL BLOCK---black with six controls--three are red, green and blue focus--the other three are screen controls--red, green and blue--- the screens are adjusted so with the color off you have normal brightness and a black and white picture--
They have nothing to do with any Convergence problem and unless they have been tampered with rarely need to be adjusted---
Let me know if this helps you AND IF YOU HAVE ANY QUESTIONS OR NEED ADVICE--LET ME KNOW.
I am here to help people.
SD TECH
Oct 09, 2009 | Toshiba TP43H60 43" Television
I can't get my speakers to work
Click control panel and when the wizard displays, scroll down for a sound settings. Set up and click sound folder and audio folder. Try every possibilities e.g. set audio to Intel (r) .... then click advance to set up volumes either you are using a desktop speaker or a speaker connected to USB port.
Jun 21, 2009 | Computers & Internet
Resolution seems to have changed
If you have xp and open the display,at the bottom click on advanced and you graph hardware page should come up, look through all the tabs until you find res, hope this helps, if not please post back your OS and what happened with what you tried and everyone is more then happy to help you more.
Mar 23, 2009 | Acer Computer AOA150 Notebook
Strange printing issue.., need assistance ASAP!!
when it receives the test page and doesn't react
1-does it go back to ready?
2-do you have to physically hit ther green button?
If everyone else can print ok then it can't be the printer !!!!
and you can ping it with no problem,
1-are you sure it is set correctly go to the properties setting under device settings is everything ok.
2-I suspect his driver is bad, try to reinstall.\
3-you can try to do a cold reset, although I don't think it will do anything since it's mainly one user problem.
Aug 07, 2008 | HP Color LaserJet 2600n Printer
Mitsubishi WS-65809 65" Rear Projection Television Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
