Question about Philips CDR785 3-Disc CD Recorder
Phillips cdr 950 audio cd recorder
Hi there,Hope you can help,Ive just bought a second hand recorder,No manuel in the box,Could you please explain how i can fix it up,And can i fix it up to my Yamaha Keyboard to record myself playing.Many thanks .
Averil
  • blondie54 Jan 10, 2008
    Hi there.Many thanks for the reply,I can see i have recorded,But i cant here anything lol ... I may have put the conections in wrong,but i will keep trying.Thanks again ,as soon as i get it working ill let you know. Averil x
  • blondie54 Jan 18, 2008
    Hi there,We have tried to get it going,My son in law can play a disk in it,BUt i cant get it to recoed me playing Keyboard .
    Averil
    Scholar:
  • 103 Answers
Hi Averil
Get yourself a copy of the manual directly from the Philips website (look on the left of the screen for all the relevant links)
Your CD recorder has a 2 pairs of phono (rca) sockets on the back.
Connect your keyboard's output (line out ideally or headphones if there isn't a line-out) to the inputs on the back of your CD recorder. And connect the outputs from the CD recorder to your amplifier. If you don't have an amp, you can plug headphones into the CD recorder so you can hear what you're playing.
Good luck! Let me know how you get on with it.
Posted on Jan 10, 2008
6ya staff
SOURCE:
Hi have just bought this used item ,no manual unfortunately,but have tried 2 diff.CDR recordable discs & all i get after reading is,wrong disc & use audio cd, hope you can shed some...
There are 2 types of recorders. Professional, which you can use any kinds of cdr blanks and the Consumer, which requires to use
"Audio or Music only" discs and harder to obtain locally nowadays, but probably plenty on line.
Oct 04, 2010 | Marantz DR-6000 CD Player
I have a Marantz CDR 615 and it won't let me record anything-any help would begreat thanks
What kind of error are you getting? Does it attempt to calibrate then display the entire disc as being full? If that try a blank that will tolerate recording at the 1x speed. Nowadays the only thing you will likely find are discs meant for audio recording or data discs that can record at speeds as low as 1x. If you can find some of the earlier kodak, Ampex/Quantegy, japanese maxells, etc then you will be okay. Also it may not be obvious but the cdr 615/620 will not record on cd-rw's
I bought one of those new and had nothing but trouble out of the phillips cdd2000 module that had to be replaced 3 times (3rd time at my expense of $300) but Superscope in Aurora, IL was good about support. Ironically I seam to remember a class action suit against Phillips over their very flaky cdd2000 drives.
Oct 01, 2010 | Marantz CDR631 CD Recorder
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sep 29, 2009 | Philips CDR770 CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Jan 13, 2009 | Philips CDR600 CD Recorder
Disc reading
How confident are you at opening it up? And where are you? If it can get table of contents info it could be gummed up grease on the laser sled.
Jun 15, 2008 | Denon CDR-M30 CD Recorder
Phillips cdr 785 audio recorder will not record. i am using digital audio cdr blanks.unit is 6 years old...has not been recording for 3 years.
time to buy new one or upgrade software
new cd/dvd formats came out maken it hard to play record or watch on outdate equipment
they remolded the cd/dvds with a new gloss
May 13, 2008 | Audio Players & Recorders
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
Recording
Both previous suggestions are wrong. Your machine displays 'wrong disc' as you are trying to use a computer grade CDR, this machine needs a 'consumer audio' grade cdr that are more expensive. Google the manual, it explains further.
Nov 09, 2007 | Philips CDR930 CD Recorder
Philips CDR785 3-Disc CD Recorder Logo
335 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
