Question about Fuji FinePix S7000 Digital Camera
View screen is jumbled and will not focus with a clear image.
Focus circle clear but surrounding area appears hazy
This is often the result of little available light on the focus screen. The more ambient light (and more open the aperture is) the brighter and sharper the image is in the viewfinder. Less light effects the image in the view finder and makes it harder to see and focus.
If your lens only opens to f3.5 or 4.0 and you\'re trying to shoot indoors with available light - your lens may not let enough light into the camera to see the scene as well as you can with the naked eye. An f1.4 aperture lets eight (8!) times as much light as an f4.0 does and is why they\'re so expensive.
Try the same setup in a brightly lit (sunny day) scene to see if it goes away.
Apr 06, 2014 | Nikon FG 35mm SLR Camera
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
Nov 29, 2010 | Canon EOS Rebel XSi Digital Camera
Image in viewfinder slightly unfocused, photo clear.
Either your viewfinder needs to be cleaned or your camera needs to be cleaned. Most of the time it is the mirror in the camera that is causing this issue and cleaning it will make everything better.
May 30, 2010 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Image focus not clear
Notice the ring around the lens, you can rotate it to both directions to focus in and out.
Open your webcam view on your computer and rotate the lens untill it is in focus
Feb 28, 2010 | Logitech Webcam
I can not get a clear picture view for my friends to see me
I do not know this webcam but, webcam focus is normally controlled by 1 of 2 means, or a combination of the 2.
Sometimes there is a focus ring around the lens which has to be rotated to achieve the sharpest image, in much the same way as a telescope.
Or, image clarity is achieved by the software and you have to manipulate the software settings for the clearest picture.
Dec 06, 2009 | GE MiniCam Pro HO98756 Webcam
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
Picture in View Finder perfectly clear, but out of focus
I would check IS(image stablization) setting and continous shooting setting to make sure these features are turned off. You want to experiment with different IS settings and definitely turn the continous shooting mode because the continouse mode may not focus 100% in order to shoot multiple shots. Hope this helps. -James. P.S. In my case it was too difficult to distinguish the quality of focus in the VF or LCD so you may not see the focus issue on them.
Apr 12, 2009 | Canon PowerShot S3 IS Digital Camera
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
Sep 21, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Diopter adjustment and viewfinder problem
Hi
I would not attempt to open the camera for any sort of fix. It has weather seals in place and would recommend sending it in to Canon. If you have any warranties left it would void these. Lastly this is a high proformance bit of kit and you want to get is seen to by an Authourised Canon Dealer.
As for the diopter adustment. To be able to see through the view finder and see your subject clearly, take of the lens cap aim the camera and turn the little dial until the screen inside the viewfinder is clear it should not be fuzzy. You are only looking at the screen/gring and not the image beyond. This does not affect your image but does effect how clearly you see your subject through the viewfinder.
Hope this helps
Regards
Jun 03, 2008 | Canon EOS-1Ds Mark II Digital Camera
Canon powershot S400 LCD screen image jumbled
This sounds like it might be a defective CCD imager. This will get worse with time, and the pictures may be jumbled next. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 21, 2008 | Canon PowerShot A75 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
35 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
