SanDisk Sansa e250 MP3 Player Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i delete music from sansa sndisk 1GB - SanDisk Sansa e250 MP3 Player
Curtis Sewell
Level 3:
  • SanDisk Master 7,482 Answers
  • Posted on Nov 19, 2009
Curtis Sewell
SanDisk Master
Level 3:
Answers
7482
Questions
Helped
1943116
Points
24946
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
My sandisk sansa 1gb will not allow me to delete certain songs, i plug it in and pop up all my music but half of it isnt even visible, is there any other way to just delete everything off the device?
Try this:
Note:Make sure you have a charged battery
Turn the player off
Slide the Lock switch ON to insure MSC mode
Plug it in your PC .Open "My Computer" ;Right click on the Sansa m240 icon
Click on Format Choose FAT..not FAT32
Click "Start"...OK
Unplug and let it finalize .Slide Lock switch to OFF.
That is all!
Not working 1gb sansa clip
What does that mean - "music db" ? I put all of my music on my 1 Gig and it works great. I put all Harry Potters audio books on my 8 GIG and still have 1.5 gig left for music.
How to download music to my sansa mp3 1gb.
I use Windows Media Player v. 11 (free software) with Windows XP transferred via the USB cable. This program will use the "sync" settings to add the music on your computer to the player. But, if the music is not in the MP3 or other compatible format for the player, then the WMP program will have to convert it first, which can take quite a few minutes if you have a lot of music.
No subcsriuption to rhapsody, can I still listen to the music
You have to renew if you want to keep the ones that are on there now. Better to delete them all, and get a free music svc like Limewire.
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
My music will not GO AWAY!!!!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Some songs wont delete
Delete from the Windows desktop if possible. Double click on My Computer. Double click on the icon of the Sansa. Go into the music folder and delete from there.
Or
Somehow i deleted everything!
There are a few different ways to delete songs off your player - see especially the method involving the firmware update.
Preventive Medicine: To prevent Windows Media Player from adding all of your My Documents files to the Sansa player every time you connect the Sansa to the computer - Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Set up Sync". When a window pops up, uncheck the box that says "Sync device automatically".
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Slow Method, allows more control over what gets deleted: In Windows Media Player 11, the files are organized by Music, Pictures, Videos, Etc. First, you will want to plug the Sansa player into the computer. Then click the Library tab in Windows Media Player. You will most likely be in Music view. You will see two sets of folders in the left-hand side of Windows Media Player. The first set are all the files stored in your computer. The second set of folders underneath the line that says Sansa 1GB Mp3 player (I forget the exact wording) has all the files that are stored in your Sansa player. Click on the "All Songs" folder. You can individually delete all the songs that you want by left-clicking once on the song name in the middle of the Windows Media Player window, and then pressing "Delete" on your computer's keyboard. You will have to repeat this process again for images, videos, etc by clicking the little arrow next to the picture of the musical note on the upper left hand corner of Windows Media Player, and expanding the dropdown menu, and selecting "images"...then "Videos" etc.
NOTE: After plugging in your Sansa player, if you see a message that says "Connect a Device" in the Sync tab on Windows Media Player, then the cmputer is not properly recognizing your Sansa player, and you may need additional instructions from me.
-Tha Mp3 Doctor
Deleting from mp3
There are a few different ways to delete songs off your player.
-Tha Mp3 Doctor
2answers
Messages that I can't get rid of
this is a common problem w/ the e250r and you can reset it by
1.Slide the button on top so it is on the orange
2.hold the record button on the left side
3.let it reset
4.download you music from a different place (not Rhapsody)
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
