Question about Baby Gear
Where can I get replacement screws? Its missing screws that fit directly into metal threading. I dont know the model because I bought it on craigs list.
    Problem Solver:
  • 9 Answers
Products America has a large slection of hardware. You can call them at 800-205-9642 or 800-772-1041 or e-mail to parts@productsamerica.com
Posted on Nov 18, 2009
Tip
Remove Thermocouple
I bought my fryer in November 2010 and it worked good for that Thanksgiving. Went to use it this year and thermocuople kept shutting off. So I used a brick to kep red button pressed in. What a pain.
After turkey day I removed my thermocouple and installed a direct conection.
I'm not sure about the exact thread size the Brinkman hose end and brass fitting on burner uses. I tried using a 1/16" NPT fitting but it is incorrect. However, I found 8mm threads to be the closet. Use thread sealant and it works great!
I bought a McMaster-Carr p/n 93590A220; Metric 18-8 Stainless Steel Coupling Nut M8 Screw Sz, 1.25mm Pitch, 38mm Length, 16mm Width, $7.95. and used it to connect the hose end to brass fitting on burner.
Yes this is considered a safety risk so modify at your own risk. No one I know of ever walks away druing use.
hth
Kenneth
on Dec 05, 2011 | Brinkmann 815-3786-0 Turkey Fryer
Tip
Bypass Brinkmann Turkey Fryer Thermocouple
hth
Kenneth
The screws won't stay in the hinges on my Maytag dryer door, model #PYG2300AWW. It's like the holes in the cabinet are too big for the screws. Is there something else missing that they should be...
Hi ddyreson...
You are missing a sheet metal clip.
It will clip on the sheet metal with the large hole in it, to convert it from a large hole to a hole that you need to fit the screw...
Look around where you disassembled the dryer, it is somewhere in the area or in the dryer...
You can get replacement metal clips at HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Sep 05, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The screw to used to move the frog to adjust the throat is missing. Can I get a replacement? Is there another part of the adjustment assembly missing?
Auctions and search engines.
Some plane Mfgs. had custom threads made. Modern bolts and screws from the hardware store may not work. Take the plane to a genuine hardware store where someone will help.
There are typically 2 slotted machine screws that secure a frog to the plane.
The plane will work fine without the slotted frog adjustment screw near the brass thumb wheel.
Really old metal planes had no frog adjustment screws.
The new frog adjustment feature did boost sales though.
If the threaded bolt for the brass thumb wheel is missing it will need to be replaced so the cutter can be easily adjusted.
Jan 20, 2011 | Fulton Tools & Hardware - Others
Mackie Mixer 1604VZL pro, needs parts
A local hardware store with drawers of screws should have what you need. The screws may be metric.
Take a sample screw with and find a nut to fit it to get the size and thread pitch. Then select a screw of that size of an appropriate length..
Nothing is worse than getting something that has obviously been worked on... you know it has a problem that they tried to fix and if you are lucky, they did not create others.
Mar 06, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Ok now that i know what i drained and it was the front gear axle oil and i temporarily used fits in tight glue because i stripped the inside groove where the drain screw goes and i stopped it for now ,i...
I worked at a jiffy lube for 7 1/2 years and have seen this alot. You have to put in what they call a helicoil. they are easy to use and can be gotten at www.helicoil.in ok hope this helps.
Oct 11, 2009 | 2001 Chevrolet S-10
Wrong screws
Hey there,
The screws for the tv are metric.
I would suggest the screws supplied with the shelf are not metric.
Try some new ones.
Sep 13, 2009 | Toshiba REGZA 46RV530U LCD TV
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Kenmore 110 timer
the allen head screw should be for the holes. they should tap themselves. with washers the metal is so thin you don't really need selftapping screws. but not know what model you have i can't be 100% sure. good luck
Aug 06, 2008 | Washing Machines
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
