Question about JVC GR-D290 Mini DV Digital Camcorder
My JVC GRD-290AG will work with mains adaptor only
My JVC GRD-290AG will work with mains adaptor but will not work with battery pack. Any ideas?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 157 Answers
What happen when you charge your battery? is it getting full easily, and once attached with your camera will work for few minutes only? If so, change your battery. Hope this helps
Posted on Mar 03, 2010
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Psp is not charging
  • Make sure the AC adaptor is properly inserted in the PSP system and that the AC power cord is properly inserted in a working electrical outlet.
  • Make sure the AC adaptor for this product is being used.
  • Make sure the AC adaptor is clean. If not, wipe it with a dry, soft cloth.
  • Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
  • If you are charging the battery pack in an extremely cold location, it might take longer to charge.
  • There might be a problem with the battery pack. For the PSP system, try using a replacement battery pack of the same type. For the PSPgo, the battery is built-in, you may need to send your system in for service.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
My phillips freevents x55p had gone into a sleep mode. when i tried to start it the screen flashed and then everything died. It was on ac power with the battery fully charged. it does not repond to the on...
removed battery pack. it then ran ok on mains power adaptor. battery but would not run either on battery alone or on battery + mains. battery pack is faulty.
Jul 31, 2009 | E-Machines eMachines Desktop PC
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    "Lens cap on" error on JVC GR-290AG DV camera
    Check customer support on the JVC website - there has been a massive worldwide problem with the CCD IC which causes the symptons you describe. They may repair free of charge even if out of warranty.
    Jul 06, 2008 | JVC GR-D290 Mini DV Digital Camcorder
    Cannot Switch On!
    There are a couple of things that you can try. plug in AC adaptor, then press the Power button again, if it work, There might be a problem with the battery pack. Try using a replacement battery pack of the same type.
    if it not work, motherboard problem, there is some fuse protection is burn. you may consoder sending it back for repair. hope this helps.
    Nov 06, 2007 | JVC Mobile Mini Note MP-XP7210 Notebook
    JVC GR-D290 Mini DV Digital Camcorder Logo
    111 people viewed this question
    Top JVC Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Steven Wander
    Steven Wander
    Are you a JVC Video Camera Expert? Answer questions, earn points and help others
