Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Unable to find my wins server.Located on the Airport page in network
  • Apple Expert
  • 481 Answers
If you are running only Apple machines, you don't even have to fill in this field. It's for the benefit of Windows machines, and even then isn't really used in personal or home networking. If you must put something in this field, just put the IP address of the router itself.
Posted on Nov 18, 2009
Airport sign in keep saying wrong password
Delete Preferred Network(s)
  • System Preferences > Network > Select AirPort > Advanced > AirPort tab
  • Under Preferred Network, use the minus button to delete the network(s) you regularly use from the list
Delete AirPort Keychain Entries (Note: only applies if you connect to AirPort/Time Capsule routers)
  • Launch the "Keychain Access" application located in /Applications/Utilities
  • Click on the "Kind" filter at the top, and look for any "AirPort network password" entries...and delete them.
  • Restart, or log out then back in.
Add Preferred Network(s)
  • Under Preferred Network, click on the plus button to add any preferred network(s).
  • Restart or log out then back in.
Jul 02, 2014 | Apple iBook G3 Mac Notebook
Unable connect server
Just switch off your router and power on again.
If the problem persists then try the below solution.
Go to
Control Panel\Network and Internet\Network Connections
In Local Area Network , check whether dns is set to automatic.
Aug 17, 2017 | Facebook Social Network
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
Aug 29, 2010 | Apple iMac Z0CY Desktop
Connecting Mac to new wireless router. Getting message: Safari cannot open page. Safari could not open the page "http://livepage.apple.com/" because the server is not responding. I'm not a normal...
Go to System preferences then under internet and network in the left hand column click on + sign at bottom of the column then under slect the interface choose airport click on create and then click on turn airport on and then select your network name and if a password is asked for put in the password.
If airport does not show up it probably means that your mac does not have a wireless card in it.
Hope this helps.
Nov 16, 2009 | Computers & Internet
Laptop unable to pick up wifi signal from router.
make sure that you airport is on and searching and update it from apple site. and check that it is in range of selected network. and go to prefrences and network then left side panel check for airport , and its settings,' then select assist me . it gave you a default location . select continue after this is finish. then go to advanced and dns server .take the ip address of that network from service provider and click on+ and put on it save your settings and start the browser. rate this if helpful.
Aug 11, 2009 | Computers & Internet
Unable to connect windows xp client to airport extreme router
If you go into the network properties of the wireless adapter you should see a tab that says "wireless networks". In the list of saved wireless networks you should see the name of your wireless network, if so delete it from the list and click ok. Try to reconnect now, I noticed this happens alot when you enter in the wrong WEP key in windows xp. hope this helps
Apr 21, 2009 | Apple AirPort Extreme Base Station...
Mac notebook unable to connect to the internet wirelessly
go to network setting then assist me , select default location after completing it . go to advance setting then check dns server and add the server ip adress in it save the settings check it is working. rate if helpfull
Apr 15, 2009 | Apple aluminum 13-inch MacBook laptop-...
Enuwi-g2 problems
What operating system are you using, Win XP?
Go to the control panel - look at Network Connection, click on properties on your USB adapter, click on Internet Protocol (TCP/IP), then Properties, make sure Obtain an IP address automatically is selected.
Also make sure your USB adapter settings (SSID, WEP/WAP etc) matches your Access Point settings.
Mar 04, 2008 | Encore Wireless Ethernet Network Adapter
WINS Servers
Are you sure that you need WINS? WINS is typically only used on a corporate network and is not used very often anymore. Whether you are using static IP's or dynamic (DHCP) you can still manually add the WINS server IP address in the TCP/IP settings of the adapter in question. If you're using DHCP, are other systems on the network getting WINS? Perhaps ths DHCP server is not set up (or not capable) to pass out the WINS server address.
Sep 02, 2007 | Computers & Internet
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
124 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
