Question about Casio Exilim EX-S880 Digital Camera
I have a Casio Ex-S880 When I push the power button the lense comes out and a picture appears on the screen but then the camera shuts off. What could it be?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 18, 2009
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
Battery charged, however camera will not stay on
This is a firmware problem that is very common in newer electronical devices especially cameras. You may get lucky enough to find an upgrade program online, but most chances are that you will have to send the camera in to the manufacture and they will repair it for $50
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
The camera turns on when the power button is pushed the start up screen comes up then the camera shuts off. Battery is fine and can view photos on card. Help!
If you mean you no longer see anything on the screen. Try hitting the picture taking button slightly and the rear view screen should come on again. This is a energy saving setting and can be changed in the menu setup.
Jul 14, 2009 | Casio EXILIM EX-Z1000 Digital Camera
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 Won't turn on
Is there a "Menu" button. If there is, press it to see if the menu shows. If it doesn't, try to take a picture by aiming the camera. then try to download it to your computer. If there is no picture, I would suggest the camera is dead. If there is a good picture of what you were shooting, then the screen is dead but the camera itself is good. In this case, you can use the camera as is or try to get the screen fixed.
Jun 11, 2009 | Casio Exilim EX-S880 Digital Camera
Power on, boots, then shuts down
I believe you have a defective Exilim memory card. Try replacing the memory card and see what happens.
Mar 27, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-S880 I put my camera on the charging dock and the orange light comes on. After about 15 seconds it starts flashing. I can't turn my camera on at all. The only way I do is to view them on...
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
Casio ex-s880 model
It could be the battery isn't taking a charge. Since your purchased the camera last February you could be still covered under warranty. I would check with Casio.com. I found this link on their website:
http://www.casio.com/support/authorizedservice/
Jun 22, 2008 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
202 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
