Question about Samsung HLM507W 50" Rear Projection HDTV
I have a samsung hlm 507wx and the bulb ticks and trys to start up multiple times and when the bulb finally turns on the screen works fine for about 10 seconds then the tv turns off and flashes the 3 leds on the front
  • Samsung Master
  • 5,138 Answers
Replace Lamp Look online Encompass Parts for Lamp# or Call 1-800-638-3328 also ck Lamp Fan if it stops running Lamp will shut Off and another thing Ballast Board is what turns Lamp on.
Posted on Nov 18, 2009
Honda odyssey will not start clicking noise when key turned
Did you ever figure this out? I have a similar problem. There is a very light ticking sound when the key is in the on position but not being turned to start. In fact, nothing happens when turned to start now. It did at least click. The batter is good and everything electrical is working in the vehicle without dimming or anything. Jumping also did not change anything.
Nov 23, 2012 | Honda Odyssey Cars & Trucks
My samsung 56" will turn on, work for 2 min or up
Samsung is actually one of the better TV's around.However,an image freezing is not from a bulb,but rather a problem within the circuitry.The circuitry problem would be more of a cause for the bulb to blow,rather than have a bulb cause other problems because it is a final output.Everything affects the bulb,the bulb doesn't affect the circuit.It could be the image processing chip.Chips are an industry term for an IC(integrated circuit).They are usually black with 16 or more legs on them.A computer microprocessor is an example of a chip basically.To pinpoint the correct one without the proper equipment or knowledge is fairly difficult,but you could call Samsung.They would likely give you some kind of an idea,but will likely say to have it checked out also.If you try to do anything to the inside of the TV yourself,take notes of EVERYTHING/ANYTHING you do because after you disconnect a couple of wire harnesses and start fishing around,possibly removing things,you can easily make a 56" paper weight out of it quickly.Greg
Feb 10, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
TV turns off
Your Ballast Board could be problem Now, pull back off watch as Lamp trys to turn on if there is a Spark coming from Ballast Board Lamp is Defective, If No Spark problem is in Ballast Board.
Sep 21, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
1999 Nissan Altima GXE Turn signal problem
you have a busted bulb, your hazard may be working fine but the bulb is double contact so one part is working and the other is not. just check which bulb is busted.
Apr 20, 2009 | 1999 Nissan Altima
Samsung flat screen problems
you will have a years guantee
Jan 06, 2009 | Samsung HL-S4266W 42" HDTV
Sharp AL-1631 copy problem
it doesnt sound like to much is rong with the scanner they all judder at start up. if there was a scan drive issue you would get a L3 error code. does the m/c continually tick over? if so then you may just be out of toner as the m/c will be trying to reach its toner levels and that can take some time.
Dec 03, 2008 | Sharp AL 1631 Copier
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
117 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
