My e1705 monitor no longer works, where can i get another monitor?
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    if this is a HP e1705 ?? and does the "on" switch stays on or blinks ?? let me know you might be able to save it , AJ
I have a Dell e1705; I had an external monitor hooked up when the LCD display died. I continued to use it with ext. monitor. However, now on re-boot it won't boot with external monitor unless I go the...
I think now problem is from Monitor side,Check with another monitor and also possibility of VGA driver problem,so reinstall driver for VGA.I think it helps. Let me know.
Jan 08, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
Monitor not working
1.remove and insert the ram again.
if not soved then,
2.Replace the Ram
Jun 21, 2010 | Dell Inspiron E1705 Notebook
Looking to show display on dell e1705 and also an IBM thinkpad at the same time for a webex My internet connection is with the dell want to use IBM as seperate monitor so two people can view easier
the only way I see to do that is a configuration where you can share the internet connection on both systems (Router) then you can view the Webex on both.
Apr 28, 2010 | Dell Inspiron E1705 Notebook
Dell Inspiron e1705 no longer recognizes AC Adapter and battery won't charge. Tried updating BIOS, but exe file won't open becuase the Flash app won't run. What can I do?
If the system doesn't recognize a the AC adapter, a BIOS flash will not run as system needs to ID the battery any AC to run the flash.
  1. Try a different AC adapter if one is available. The system IDs the adapter by the pin in the center of the DC connection to the system. If the pin is bent or missing, then the system cannot ID the AC adapter and the Battery Charger is disabled.
  2. If issue occurs with a new or known good DELL Branded AC adapter (Any Dell D Series adapter should work on system) then the motherboard is bad.
AC adapters run about $25
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=e1705+ac+adapter&_sacat=See-All-Categories
Motherboards around $150
http://shop.ebay.com/i.html?_nkw=e1705+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Laptop_Adapters_Chargers&_odkw=e1705+ac+adapter&_osacat=0&bkBtn=
Apr 03, 2010 | Dell Inspiron E1705 Notebook
Dell Inspiron E1705 monitor changes brightness
If you have your Dell driver disc have to uninstall the video adapter driver and reinstall it. Restart the laptop and observe if things still happening. No need to do an update for the video driver though on this regard. Or on the other hand try to do a System Restore. Restoring your computer profile/settings on the previous date that it was working fine. But before you gonna do that have to back-up first the important files that you have to your external hard drive or USB flash drive. Hope these things help. Thank you.
Oct 09, 2009 | Dell Computers & Internet
E1705 Monitor is black also, but can see this screen fine on tv
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Dell Inspiron E1705 Notebook
Dell E1705...Same problem...lights on boot up
If the screen goes dark after BIOS, there is a software conflict - either a driver or screen resolution was set incorrectly. a couple of ideas to solve:
boot from disk, or another hard drive - if this works, it confirms the software conflict - which would mean having to re-install the OS.
Jun 24, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Spilled soda on it!! No picture!
i think you just damaged the wiring, soda is like some kind like a acid. which can do so
Feb 05, 2009 | Dell Inspiron E1705 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
